Battery Tender Plus indicators
Old Feb 17, 2014 | 10:03 AM
kerflumper's Avatar
kerflumper
Default Battery Tender Plus indicators
I have the Battery Tender Plus hooked up to my battery. The red light is supposed to come on when it is charging. The green light is supposed to blink if the battery is more than 80% charged and be solid when charged.
I just went out to look at a few things. (Green was solid when I started) I had the passenger door open for about one minute then the driver door open about one minute. I looked at the tender and the red light is solid. No blinking green. The battery shouldn't have lost 20% of its charge in two minutes of the door being open. The battery is about 6 months old.
Old Feb 17, 2014 | 10:14 AM
SONKIST's Avatar
SONKIST
St. Jude Donor '07
Mine does the same thing. I wouldn't worry about it.
Old Feb 17, 2014 | 11:04 AM
Landru's Avatar
Landru
I don't use a BTP, have another brand; BUT, while hooked-up I've opened the door to retrieve something and when finished locked it back up.
Luckily I re-checked the unit. Red lamp was flashing indicating a default. Disconnecting & reconnecting reset unit & all's fine. My unit, for some reason, faults out when car power's activated with this unit.
Had I assumed it was fine I'd have been SOL.
IF you haven't done so already, disconnect the unit & reconnect it just to be safe. Lamps *should* be normal.
Old Feb 17, 2014 | 11:13 AM
dvilin's Avatar
dvilin
Same here.
Old Feb 17, 2014 | 11:15 AM
kerflumper's Avatar
kerflumper
I just checked it and it's green now.
Old Feb 17, 2014 | 11:38 AM
Red08's Avatar
Red08
Totally normal - those battery tenders are very sensitive to any amount of battery drain, even if just opening the door for a minute or so.
Old Feb 17, 2014 | 11:30 PM
Gary '09 C6's Avatar
Gary '09 C6
The tender is just "topping-off" the charge...20% of the charge hasn't been lost.
Old Feb 17, 2014 | 11:44 PM
4SUMERZ's Avatar
4SUMERZ
Totally normal if it turns green again in an hour or so. If longer than that, start 2nd guessing the battery or the hook up.
I had a new Yellow Top that went bad, and the slightest draw (door open, or inputting NAV directions), the battery drain was really quick, and the Plus would take a long time to get back to green.
The battery had a bad cell and it was less than 1 year old.
Old Feb 18, 2014 | 11:36 AM
mikeCsix's Avatar
mikeCsix
The Battery Tender, and just about all of the 'float' chargers, don't produce a lot of current. When you start opening doors and turning on those inside lights, they will easily draw more current than can be supplied, cycling through its stages. In Other words, the responses you see from the BT are normal.
What I look for in battery tenders is the float voltage, I like to see it around 13.2vdc.
One item will help is the switch to LED's, but really isn't needed, I've brought back some pretty flat batteries using just a BT.
To Battery Tender Plus indicators
