Cam question
Old Feb 18, 2014 | 03:36 PM
MuscleHP's Avatar
MuscleHP
Default Cam question
I have a 2005 c6 A4 with cai, and full exhaust.
I want to cam my car, but I also want to keep my stock stall.
I Really want a cam that chops and sounds great. I don't mind having to keep my foot on the brake harder I just don't want the car to push through the brakes.
Any cam opinions or suggestions or personal experience would be great.
Thanks guys
Old Feb 18, 2014 | 04:43 PM
jbomx363's Avatar
jbomx363
Tech section and you will get some answers.
A few threads on this exactly.
EDIT: Forgot to add link:
http://forums.corvetteforum.com/c6-t...am-update.html
Old Feb 18, 2014 | 05:01 PM
MuscleHP's Avatar
MuscleHP
Okay thanks. I always forget about that section
Old Feb 18, 2014 | 05:05 PM
Don-Vette's Avatar
Don-Vette
You really need a good combo along with the heads,check this out at forum vendor WCC...
http://www.westcoastcorvette.com/p-2...07-c6-ls2.aspx
Old Feb 18, 2014 | 05:44 PM
PRE-Z06's Avatar
PRE-Z06
We've done some cammed cars with stock stalls and most are sleeper grinds ie they don't lope. The lope is from the overlap, which causes the idle speed to need increasing which is why people say it pushes through the brakes or is on the converter...if you have a strong leg then it won't be as noticeable or may not mind as it will just take more effort to keep the car stopped. Hope this helps, don't hesitate if you would like a quote. This is as big as I'd comfortably recommend in an LS3 car, more cubes can soak up more duration and no cats is going to sound meaner than with cats especially if NPP is open...
http://forums.corvetteforum.com/c6-t...post1586205806
Old Feb 18, 2014 | 08:45 PM
MuscleHP's Avatar
MuscleHP
After everything I've read and talking to a few buddies , I guess I am going to go with a stall. Lol
To Cam question
