A wolfdogs first!!!!!
Time for clean up
Some kind of State license?
That would bug me and it looks huge too.
What gives?
I'd vent the dryer outside too although I would imagine the hose would need cleaning often being so long...hence another problem.
No need to reroute or extend dryer vent hose.
^^just as dusty, cleaned only with a CA Duster once a month (whether it needs it or not) since 2/08^^
I recommend the need-for-speed method. Then you don't need to raise the hood (or remove the car cover) to connect / disconnect the batt tender. I use this method on my Corvette, Camaro, and Silverado.
I wired the ring terminals from the battery tender supplied harness to the small screw on each battery terminal. After I took this picture, I revised it. I bought another nut for each terminal and sandwiched the ring terminal between the original nut and the added one.
If you don’t buy the extra nut - when you loosen the original nut - it can loosen the cable clamp - so beware of that.
I bought a 12 foot extension harness made for the battery tender from batterymart.com. I put it all under the hood, and routed it out through the front grill, secured it with a tie wrap, and left enough length to fold it back in place when not connected. I can hook it up without ever raising the hood.
Just be sure to put a red rag on the windshield when it's hooked up so you don't forget and hop in and drive. (ask me how I know
There you go - no need to ever raise the hood to plug it in. Just like an electric car, with 436 HP
http://plumbing.about.com/od/Dryer/t...ccessories.htmWOLFDOG CHECK OUT THIS WEBSITE AND DO NOT USE FLEXIBLE PIPE
