Trailer Frustration
So, after a couple hours of effort and frustration I've had to make the decision to cancel the appointment. I'll have to try and find someone in the area with a low angle trailer ramp or wait till the roads clear enough so I can drive the car to the body shop. Oh well, could have been worse, I could have screwed up the C6 loading, in transport or unloading. Better to deal with another day when the conditions and transport are better suited for the day.
was going to suggest the same, the wood boards are needed. I need to use them when trailering to the track
The RR-80-10-2 model is a regular Race Ramps product. The incline section has an 8.5 degree incline.
The RLL-80-2 model is a Reverse Logic custom product with an incline section that has a 6.8 degree incline. The incline sections for this model are available separately for someone who does not need the platform for use as a service ramp.
http://www.reverselogic.us/shop.html...49&id=19995831
I currently own the 2-piece 67" ramps and Xtenders, not sure I want to invest another chunk of change for this event. Guess I should have waited and purchased the combo units.
Fred - do you have any thoughts if I can use the RR-XT-2 67" productinverted like the combo incline unit?
Since the RR-80-10-2 and RLL-80-2 ramps have incline sections intended to be used as trailer ramps, the steps on the inclines ARE reinforced. Also, the shape of the interlock on these two ramp models is designed for use with trailer doors and ramps when the inclines are inverted.
If you flip the RR-XT-2 inclines for use as trailer ramps, you will almost certainly damage the inclines.
It is unfortunate that you were not aware of the combo service/trailer ramps since they are less expensive and offer more functionality than the combined RR-XT-2 ramps and RR-EX-14 XTenders.
You can probably sell off your existing ramps and upgrade to the new ones for about a $100 investment. The RR-80-10-2 or RLL-80-2 ramps run around $350 +/- $10 after discounts and factory rebates. You should easily be able to sell your RR-XT-2 + RR-EX-14 ramps for $250.
Also, you might be able to find a place where you can get the trailer lower and the car higher....maybe on an incline or backing the trailer up to a high curb (where you can get the car up on the high side). Kind of a 'loading dock' if you will. Your best bet is to use boards/ramps and jacking-up the front of the trailer. Good luck.
Also, you might be able to find a place where you can get the trailer lower and the car higher....maybe on an incline or backing the trailer up to a high curb (where you can get the car up on the high side). Kind of a 'loading dock' if you will. Your best bet is to use boards/ramps and jacking-up the front of the trailer. Good luck.You won't find the HD versions listed at the manufacturer's website or at most resellers. I don't know of any resellers that stock the HD models other than Reverse Logic.
The HD Roll-ups are rated at 5000 pounds per pair and will raise the rear tires of your tow vehicle 4". This probably translates to closer to 5" or 6" at the hitch.
http://www.reverselogic.us/shop.html...72&id=20368192
OK, some applied logic...
There is a group I track with, some trailer thier vettes regularly. Lessons Learned.
1. Large chalk block for the tounge pad. Lower it down as far as you can crank it. Lifitn the Arsss end of the truck and tounge of the trailer. There by decreasing the angle of the rear ramp door. The idea of backing up on ramps would do the trick too.
2. Chalk truck or trailer tires...very important. Safety first
3. 72 inch race ramps on the edge of the ramp door and they are loaded or unloadedin 15 minutes. 2x10s coujld also work.
Good Luck...oh -5 burrrrrr, -8 here and for the next three days.
Here's what I am thinking through now.
- I played with some boards I have over lunch today - I'm very concerned about how slick they are with these low temps and with the hard rubber on the GY OEM tires.
- Thinking that maybe I can push the Vette down the road, about 3/4 mile, over the snow and ice to where I get clear road and then carefully drive it the 45 miles to the body shop this next weekend. Temps are supposed to finally get up around 20 during the daytime.
- Otherwise I may order the combo ramps and try again.
- Last option is to wait till the weather clears and road is passable and just drive it down in May or June. Just hate to let any time pass in the short summers here without driving my C6.
Reactions?
*Disclaimer: I have never done this and personally, I would wait. This is just an idea*
If it is only the front bumper that is the issue, you could use a jack and some jack stands.
1. Line the trailer up first and keep it attached to the truck
2. Jack up the front of the car until the angle is enough that the ramp will clear the bumper.
3. Support it with jack stands so left and right are level.
4. Back the trailer up until the wheels are touching the ramps. Remember, you will lose a few inches when the car is supporting its own weight, so make sure it is high enough.
5. Secure and prepare the trailer, remove the jack stands, and slowly lower the car onto the ramps.
Make sure someone is spotting you on the mid part of the car, as you may bottom out there.
No clue if this would work. I have never put my car on a trailer. I need to use 2 2x10s just to get a older "low profile" jack under it.
I did some cutting on boards as suggested and elevated them similar to using the trailer. Then drove up on with wife's Explorer and they were still a bit too slippery for my liking.
I'll likely just sell my current ramps to someone and then order a set of the combo ramps as suggested by Fred. May try to convince the guy that owns the trailer, actually has 3 of them, that he ought to buy the combo ramps instead and then I can just use them as needed. He mainly hauls 60's/70's cars with plenty of clearance so hasn't had a need for low ramps/trailer ramps.
Thanks again for the suggestions.
