coolant temperature
I floored my 2005 MZ51 to beat out poor soul who I should have just let him go.
Afterwords I got a message check coolant level. Checked it it was fine. Message went away.
However coolant temperature hit 237 . I don't recall ever seeing that.
after a a while of easy driving it went back down to 195. But at stop lights it crept back up again. Its cooling down now in the office garage. Oil tempt was always fine.
btw - its got a new water pump and radiator in it. Just had all fluids changed about a month ago
anyone else experience anything like that?
how do you spell head gasket ?
You may have an air bubble in the coolant from the fill. That is not uncommon if not done correctly. Search the forum for burping the cooling system.
anyone actually know? if so, the correct answer needs to be added to the faq.
I'm looking at the stock table right now from my 2005 corvette HP tune file (system/fan) and it looks like this.
199*, fan at 15%
203, fan at 23
207, fan at 31
210, fan at 39
214, fan at 47
217, fan at 56
221, fan at 74
225, fan at 90%
As for lowering the fan temps per speed amount the fan is going to run, its a double edge sword. The problems lies in the connector for the fan, and if the fan runs too long at at higher percentage, then it burns up the connector. This is pretty much why GM limited the fan to 90% output max, and why it does not go to that until you get to higher temps. So when you do lower the fan run percentages per temp, don't go buck wild and have the fan running 90 at normal temps!!!
P.S, with a new radiator, I going with air still in the system, and will bank that when the installed the new T stat, it did not have a air bleed passage on it.
On this T stat, the brass piece on the flange of the stat allows air to be released out of the system, even when the T stat is closed (nubby piece installs dead center top).
On the stock T stat, no bleed channel in the top of the flange, so the pressure has to be great enough to allow the air to be forced down and through once the T stat starts to open up instead, and traps air in the system a lot longer until is self bleeds with the T stat opened instead. To solve this problem with a stock T stat, you just drill a 1/8 hole through the flange at the same location that the first T stat has the brass numb, hence so the channel is at the top of the flange with the T stat installed. This allows small amounts of fluid and air to pass through the stat when it closed, instead of having two vacuum areas in the system on either side of the T stat that will trap air when you are filling the system back up.
199*, fan at 15%
203, fan at 23
207, fan at 31
210, fan at 39
214, fan at 47
217, fan at 56
231, fan at 74
225, fan at 90%
199*, fan at 15%
203, fan at 23
207, fan at 31
210, fan at 39
214, fan at 47
217, fan at 56
221, fan at 74
225, fan at 90%
I apologize that you are experiencing concerns with the Vette. Have you already taken it in to the dealership then? Let me know if you would like me to look into this further for you and I would be happy to. If this sounds like a plausible idea please private message me your contact information, VIN, and the dealership name/location. I will be looking forward to your response and I hope to hear from you soon.
Jennie R.
Chevrolet Customer Care
Same here...
