Anyone using "leave-in" jacking pucks?
I had the Elite Eng ones installed for years. I put a dab of silicon on them before I locked them in and they stay put. I like them always there so if someone jacks them up, they see them and use them and I don't have to worry about forgetting to put them on.
Not looking to start an argument here. But this is no cheap joke:
http://forums.corvetteforum.com/c6-z...ng-damage.html
http://forums.corvetteforum.com/c6-c...el-damage.html
http://forums.corvetteforum.com/c6-c...age-story.html
Over the years I've seen a number of these reports. It's a C5 problem too.
Not every owner is fanatical about their Corvette. Some folks never look under their car. They might never see a damaged rocker until they try to sell -- and a potential buyer does an inspection.
And it's easy for a service guy to deny responsibility if the rockers aren't inspected before and after service.
Even if you can prove a dealer is at fault, it's still a headache getting it fixed.
IMO the leave-in-place pucks are insurance. Buy 'em -- or take your chances.
What happens if you get distracted or interrupted and you forget to put them in that one time you use a tire shop ??
Thats why I used GOOP to secure mine, its semi permanent. Even if the tire shop didn't want to use them, they have no choice except to pry them off which I can't imagine them doing, (liability).
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
I can't imagine why you would want the pucks to be removable, they don't get in the way and it would be easy to forget to tell the tire place that you have pucks or remember to put them in yourself.
The forgotten pucks could result in thousands of dollars of damage to the underside of our cars. Why not put them in semi-permanently? Goof proofed.
I have used since 2000, std hockey pucks, costs about $2 each, new. I use an adhesive called GOOP from Home Depot. It holds like iron my if you need to remove them you can use a fishing line to saw them away from the adhesive or simply use a screwdriver to pry them loose.
2000 C5 ,4 pucks stayed on for 4 years, 2004 C5,4 pucks stayed on for 8 years, current C6, 4 pucks have been on 2 years and aren going anywhere.
I love corvettemods but why pay anything over $8 for new pucks or free from your hockey friends and $0.50 worth of GOOP to protect yourself even if you forget to use them ?
CI 1-4-5-8-9-10 Vet
Have y'all ever heard of an instance where the car had the pucks in place and some shop still managed to damage the rocker panels? It seems like there's still room for error.
Why not leave them in place? Put mine in the week I took delivery on my 2013 Grand Sport and they are still there after nine months and 3800 miles. Can't image them being "caught on something and rip out" unless a lot of other undercarriage items get damaged also. It's just a matter of personal preference.
Cheers - Major Boyd
Cheers - Major Boyd
Need-for-speed,
You asked,"did you put any hardware on them to engage the hole in the frame, or are they just glued on?"
To answer your question, I did NOT use a bolt through the center of the puck, Im sure it wouldn't hurt but as I as I said I used GOOP, and only 2-3 tylenol size drops on each puck. I did try to stack some material under the puck so the puck could make full contact but after 24 hours, the pucks were secure, I couldn't pull them off by hand.
The pucks I put on my 04 C5 were still there when I sold it in 2012. Im a big user of GOOP, it hasn't failed me yet and whatever you secure can be separated if you don't overdo it with the GOOP.
#33
I read about rattling here on the forum. Got mine from Corvette Mods also. I drilled some weep holes through them and ran a bead of black RTV around the rim before I popped them in. Probably a totally unnecessary process, but they do not rattle.
#34
If I need them for something I'm not doing in my garage I just take them with me. Simple and I don't have to worry about losing one or two and finding out when I most need them.
#35
No. Even with windows down and no music, they don't rattle. At most, they spin around on there axis. But since reading this thread, I decided to add some goop to better secure them in place. But not because of rattle, just for my piece of mind.
#36
CI 1-4-5-8-9-10 Vet
Need-for-speed,
#38
I would and have done the same thing as far as taking the wheel off (or all of them) at home. As far as the pucks, I've had the BMW's in one of my C5's and have had the same set in my 07 since new.....you NEVER know when you might have to have it jacked or lifted. They don't get in the way, you can't see them so they work for me. Mine are in tight, no rattles...
#40
Ok..so now you guys have me worried. I bought a 2011GS in January and last month had Discount tie install 4 new Michelin PSS tires. I watched them do everything. the put do jacks on each side of car and two guys working in sync slowly raised it and lowered same way when done. I just went and looked under the car and see no damage, doors work smoothly etc. Are C6 frames so damn weak we have to worry about the car being lifted or what is the deal? I have no pucks but now wonder if I should get them and why specifically. Would seem factory would have something like that on the car if there was an issue. help me understand this.
