brake pad question
Old Apr 14, 2014 | 08:58 PM
HBsurfer's Avatar
HBsurfer
Default brake pad question
Looking for some advise on brake pads. I have a 2007 base coupe, 3lt and Z51. I am not a hard driver and the car will never see a track. Usually used on weekend drives in the mountains or on Pacific Coast Highway. Should I replace with stock pads or do any of you have an opinion on what aftermarket pads I should install?
Thank you,
Tony
Old Apr 14, 2014 | 09:04 PM
Boomer111's Avatar
Boomer111
If the stock pads worked well for you I would stay with them. Why bring on unwanted problems.
The OEM should be fine for your type of driving unless you had issues and wanted a change.
Old Apr 14, 2014 | 09:14 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Thank you,
Tony
Tony, take a look at the Carbotech 1521 pad. This pad is a low dust performance street pad that will deliver the performance you want from your brakes but, with out the dust and noise. A pad description is below along with pricing, if interested I will be happy to help you.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
F $140 R $121 Includes 5% forum discount.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Apr 14, 2014 | 09:34 PM
L82Brake's Avatar
L82Brake
For a little less bite but low dust go with the GM Ceramic.
Old Apr 14, 2014 | 09:59 PM
traderfjp's Avatar
traderfjp
Love my Ac Delco Ceramic pads. Very reasonably priced, super quiet and so easy to install. I did mine this weekend. Each wheel can be done in 30 minutes. That is roughing up each rotor, cleaning each caliper, and replacing the pads. The pads pop right into place. A monkey could do it. I also didn't notice any difference in braking power. Can't comment on dust or lack of it but there should be minimal dust. Brake dust was the primary reason I changed out the stock pads.
Old Apr 14, 2014 | 10:15 PM
KC-Vette's Avatar
KC-Vette
On my '08 Base coupe 3LT, I went with GM Ceramics from my dealer. I was very happy with them. Hardly any dusting, good pedal feel.
On my 2010 GS Coupe 3LT, I ordered Hawk Ceramics from Patrick at GM Parts House. Not sold on the Hawks. They only reduced the brake dust by half, and questionable pedal feel, especially in wet conditions.
Some on here have good reports about the pads sold at AutoZone. Much cheaper, and they favor them. My two cents...
Old Apr 14, 2014 | 10:23 PM
Orange05_C6's Avatar
Orange05_C6
I just went with some cheap ceramics off ebay. very low break dust, less wear on rotors, still will make the seat belt choke you from the stopping power. I'm happy with mine
To brake pad question
