Has anyone without experience installed there own clear bra? If so how did it go and would you do it again. This would be using a pre cut kit. Thanks in advance: confused:
ehh............. I didn't do it myself, but I watched a pro do it on my car. And, unless you have lots of patience, can work fairly quickly, have the skill to wrap it properly I would not recommend doing it. The cost to have a professional involved is worth it.
Doug
I am having mine done this weekend. There is no way I would take a chance of screwing it up.....which I would do!
1. buy a piece of clear bra for 1 mirror,,,,try to install it and make it look perfect,,,
2. Find local shop that provides professional installation,,,
Pre-cut kits are fine, but a true pro will cut every piece by hand. Much better than the kit.
I think I would have to disagree with this. I've seen three booths at events like Mid-America Motor Works Funfest where they custom cut everything from bulk film rolls on CNC laser tables. It's fast and the pieces are exactly the right size & shape.
That's what I had done to my Red at Funfest 2013 last September. The professionals first removed the faded, 7-years-old and worn out 3M film that had lost all its gloss. They used a fabric steamer to soften both the film and its gum adhesive. The old stuff came off like giant pieces of Scotch tape. After claying the surface underneath, it was just as shiney and perfect as it was when I picked Red up from the Museum in Aug 2006. Then they applied freshly cut XPEL sheets over the entire nose, mirror fronts, and rear bits of the wheel wells. It looked (and still looks) gorgeous -- every bit as glossy as a good Zaino polish.
I installed a clear bra on my wife's new genesis coupe. It was a learning process and not easy. It turned out good but not perfect. But now that I've done it and understand how to heat and stretch the material to get it to fit, i could easily do it again and have it look near perfect.
My recommendation, if you've never done it before... you don't want to learn on your vette.
I think that's what I said. My guy hand cuts all pieces.
I agree with letting a pro do it but most pros use a program in a cutting machine to cut the different sections needed. Never even heard of one that cut by hand.
So, first I bought pre-cut pieces from Cleartastic. When they arrived and I read the instructions, knowing that I have almost zero aptitude for fine hand work, I got Expel put on by the pro's. They did a great job, and, for me, it was the right decision.
Here is why I ask... I can go with expel order bumper, full hood, full fenders, and mirrors for around 700.00 material only I install... Or go with 3m partial hood, partial fenders, front bumper, and mirrors for 600.00 installed.... The reason this is tuff decision is my vette budget is very limited right now because I bought this car and my original budget was for a ç5.. And I ended up with this c6.. Which I have no regrets doing..
The guy who installed my GS fender stripes said that all clear bras will eventually turn yellow and he would not recommend one to anybody. One man's opinion?
That's not what he said and I will disagree with your point. He stated the plotter cut the material which is precut kits. Custom cutting is a DIFFERENT skill set but not better in any way. A lot of custom installers have a hard time with kits because they actually have to make the material fit perfectly where as custom cutting they stretch a large piece and cut everything by hand. MOST custom installers cut the paint up. You just don't know it because the cuts are along the film lines.... so unless you remove it you wont know its cut. I have done both types of installs and both are very different. A good precut kits with wrapped edges is just as good as a custom cut. its all coming out of the same material.
By the way who is your guy? I am pretty sure I have been out to your place before... if you are who I think you are.
