Squeaky top?
Old May 27, 2014 | 12:58 AM
joliett's Avatar
joliett
Default Squeaky top?
I was maintaining a no squeak condition by using a drop of lithium grease on the tiny roof rollers, and a "Rubber Care Stick" called "GUMMI PFLEGE STIFT" made in the Netherlands and available here in the USA.
Yes, the small sponge applicator container works really great on the weather-stripping everywhere on the C6.
BUT...after my roof flew the &*^%$ off for god knows how many times, as I was assembling the new roof - I notices the back alignment pins on the top were loose. So I tightened the hardware on the rooftop, and my C6 rides (and sounds) like new...solid as a Corvette should be.
Just a solid tip. I swear - do this and your roof's squeaky problems will be gone.
Old May 27, 2014 | 04:29 PM
Robert Gaspar's Avatar
Robert Gaspar
Cruising
Stopped my squeaks with Di-Electric grease on the rubber and with Danco #780 O-rings - 2 on each of the front posts and 1 on each of the back posts. Works like a charm! My thanks to guys who steered me right on this thread.
Old May 27, 2014 | 04:48 PM
biggerjer's Avatar
biggerjer
Great tip, but did I read that right? Your top flew completely off of your C6 multiple times? Why? I don't want that to happen even once.
Old May 27, 2014 | 05:20 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Both of the front pins on our 2009 have come loose in the past, I clean the threads and use blue Loctite to keep them in place.
I also use the dielectric silicone grease, as recommended in the owner manual, to keep all the weatherstrip from drying out and squeaking. I tried the GM Superlube paste that they recommend in the noisy top bulletin, but it dried out much faster and left a real mess.
Old May 27, 2014 | 05:38 PM
biggerjer's Avatar
biggerjer
The dielectric grease is cheap (relatively) and works fine for me.
Others on another thread have recommended plain old silicon spray lube,
may try that and will also check those pins so my top doesn't go wining off.
To Squeaky top?
