Quick question
Old May 29, 2014 | 02:17 PM
aliveagain1803's Avatar
aliveagain1803
4th Gear
Default Quick question
I have a C6, and I just wanted to know if the smell of gasoline (inside the car) is normal. Especially in the heat/ summer. Thanks.
Old May 29, 2014 | 02:23 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
NOT normal.
There can be several causes, and most of them have the potential for a big problem. Some are relatively cheap/easy fixes, others are complicated and expensive.
Either way, you want to find and fix.
On our 2009, I started getting gas smell only after filling the tank and doing a hard right turn within the first 50 miles. A new gas cap solved my problem.
I hope yours is that easy...
Old May 29, 2014 | 02:36 PM
dvilin's Avatar
dvilin
All I can add is the smell is not normal.
Old May 29, 2014 | 02:38 PM
aliveagain1803
4th Gear
Originally Posted by Gearhead Jim
NOT normal.
Yes! now that you mention it. The smell is strong after filling the tank. Thanks!
Old May 29, 2014 | 02:42 PM
spdkilz911's Avatar
spdkilz911
When filling the tank do not put another drop in after it shuts itself off. Trying to squeeze in more or round off the numbers will cause the smell.
Old May 29, 2014 | 02:43 PM
biggerjer's Avatar
biggerjer
Still not normal unless you are spilling fuel when filling, try not topping off after shut off. If you still have problem check filler neck.
Old May 29, 2014 | 03:38 PM
jwf's Avatar
jwf
Not normal at any time.
Old May 29, 2014 | 04:19 PM
jedblanks's Avatar
jedblanks
It happens to me when the d-bag before me spilled fuel and I have to stand in it to refuel my car. Gets on shoes and then in car with me
Old May 29, 2014 | 04:26 PM
SmileyOr's Avatar
SmileyOr
Are you guys filling up on a fast fill setting or the slowest setting on the delivery handle?
How well do the tanks siphon over to the opposite side when filling?
Old May 29, 2014 | 04:33 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I normally use fast fill until I only need another couple of gallons, then shut if off and do a slow fill for the remainder. I have a pretty good idea of how many gallons it'll take to fill the tank. Going all the way on fast results in gas squirting out when it shuts off, and it gets all over the fender.
I guess it transfers from one to the other fine. I've never had a problem with it.
Old May 29, 2014 | 05:32 PM
VET4LES's Avatar
VET4LES
Not normal.
Old May 29, 2014 | 10:34 PM
Gearhead Jim
St. Jude Donor '13
Each of the little tic marks on the gas gauge is very close to 1 gallon, I can usually predict within 1/2 gal how much mine will take to fill up. I tried topping off just once, and, like everyone says, it just results in slopping gas all over the fender. Let the automatic shutoff do it's job, on low flow, and you'll usually be right on.
Old May 30, 2014 | 08:28 AM
wayback's Avatar
wayback
Be very careful when filling up and do not spill/overfill. If you still have the smell I would take it to a competent shop.
I had the same smell and the dealer did a smoke test. Found the evap line was leaking right off of the fuel pump. Changed the fuel pump under powertrain warranty and all is good. Hope you are under warranty as this is not a cheap fix....with A6 they have to drop the transmission and cost was $2500.00. Thank goodness it was covered.
Old May 30, 2014 | 08:48 AM
87SAM's Avatar
87SAM
Leaving the window down could possibly allow fumes to enter the cabin during the fueling process.
To Quick question
