need some help here...
Old May 29, 2014 | 05:40 PM
Ironhead621's Avatar
Ironhead621
Default need some help here...
So after about two weeks of not driving the vette, I go to work today and on the way home, I put it in sport mode....and...it won't down shift. It will upshift....but not downshift. I recently had a bout with a dead battery and have since charged it and have had no problems. I can't remember when the last time I used it in the sport mode, but I know everything worked fine. Any help?
Old May 29, 2014 | 06:30 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
I realize how displeasing it can be when faced with a transmission concern like this Ironhead62, and though you're seeking thoughts and opinions, I would be happy to communicate this situation with the designated Customer Experience Manager at your preferred dealer if you feel an official diagnosis is necessary. Feel free to message us privately if you'd like to proceed, or discuss this situation further.
Kindly,
William R.
Chevrolet Customer Care
Old May 29, 2014 | 06:46 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
So in the sports mode you can up shift with the little buttons on the wheel, but the paddles behind the wheel are not manually downshifting correct. It will downshift automatically as you slow down but only to 2nd. So is yours doing that? Did you try both paddles?
Old May 29, 2014 | 08:27 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Can you give us a little more info? You put it in sport mode, are you using the paddles or are you letting the trans do the shifting?
Old May 30, 2014 | 07:33 AM
Ironhead621
I can upshift with the paddles in sport mode, but i can not downshift with either one. The car will automatically downshift in sport mode as i slow down. It will go into 2nd gear when i stop but can not downshift to 1st.
Old May 30, 2014 | 08:02 AM
Don-Vette's Avatar
Don-Vette
Sounds electrical. Check all wires from transmission and paddle wires.
Old May 30, 2014 | 08:04 AM
EBvette02's Avatar
EBvette02
Do you get an X over the gear indicator on the HUD? When you try to downshift?
I know I see that when I try to downshift to a lower gear and I'm going to fast.
Old May 30, 2014 | 09:55 AM
Ironhead621
No x over the gear indicator...experienced that before.
To need some help here...
