Help with engine issue
Old Jun 5, 2014 | 07:57 AM
Triumph Jerry's Avatar
Triumph Jerry
Originally Posted by papadr
Sorry I am a " newbie". It is a GS in red. Model LT4 ,manual with dry sump.
That's fine, you see even the color is important because the factory
might have had a problem with some production runs involving one
color.
Yep manual GS is a dry sump engine, and they hydrolocked it by
starting it with twice as much oil as it should have and broke something.
The white smoke is coolant being burnt.
Old Jun 5, 2014 | 08:35 AM
jedblanks's Avatar
jedblanks
Originally Posted by SCcues
How in the world do you put the oil in the wrong hole?
That, sir, is what she said...
Old Jun 5, 2014 | 09:06 AM
Don-Vette's Avatar
Don-Vette
Old Jun 5, 2014 | 09:38 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Originally Posted by HOXXOH
...Drive it hard for a few days and keep close track of oil and coolant temps along with oil pressure and volume. If it breaks even farther real soon, there will be little doubt that the oil change error was the cause.
As you see from the other responses, white smoke MIGHT be oil or fuel but it is most often water from a ruptured head gasket. This will probably result in water in the oil. Check for white foaming of the oil. Also watch for larger than normal changes in water level between hot and cold. You could also have piston/ring damage that could be noticed by different sounds.
The mechanic knew nothing about your engine so probably assumed, like all other engines, it had only one drain plug. It has two and when the second wasn't drained the engine was overfilled and the pressure could have done a lot of damage. It isn't running without oil that is your issue, it is running with too much. That is why the supervisor drained ALL the oil and refilled properly.
Maybe you got lucky and the mechanic underfilled at first expecting to top it off after it was running but stopped the instant it smoked. More likely you have significant engine damage that will eventually show up. The sooner you determine which is the case the better.
Old Jun 5, 2014 | 10:29 AM
Chevy-SS's Avatar
Chevy-SS
Originally Posted by saplumr
Not necessarily. I had 2 60# fuel injectors stick wide open and it was a complete white out behind me. Just one of those little things I found out.
Fascinating info. I would have guessed black smoke with uber-rich fuel mixture...... maybe you had some antifreeze in the gas??? hahah, j/k
