Help with engine issue
Old Jun 4, 2014 | 12:51 AM
papadr's Avatar
papadr
3rd Gear
Default Help with engine issue
I took my 2011 Vette into a Chev dealer for an oil change.They called me and said it was ready.I showed up and they had not started to work on it.Said they could do it in very little time and proceeded to put it on a hoist.15 minutes later car is back on ground and they start it up ,at which point thick WHITE SMOKE comes out the exhaust.I and the service mgr are watching .He says more problems than not having the car ready ,the mechanic has put the oil in the wrong hole ????He did not elaborate and I had to leave for an appt.
What are the possibilities ? No oil in crankcase when it started? he put oil in radiator or transmission ??The car ran less than 2 minutes. How much and what kind of damage could he have done.
Hard to believe this could happen on a simple oil change.This is a large GM dealer selling lots of vettes.
I am going to talk to them tomorrow ,but am not very technically proficient. I don't want to find out six months from now I need a new engine on a car with 12000 miles.
Thanks Dave
Old Jun 4, 2014 | 01:39 AM
BayouCountry's Avatar
BayouCountry
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Search for dry sump. I'm guessing they didn't fill it there.
Old Jun 4, 2014 | 05:41 AM
Triumph Jerry's Avatar
Triumph Jerry
What is the car?
C6? GS? Z06? ZR1? If you have a problem always give all car info, even the color.
'09 C6 M6 Arctic White, Stock
Old Jun 4, 2014 | 06:35 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
It's white smoke ..... not blue, more likely it's just condensation in the exhaust.
This is your first post .......
Old Jun 4, 2014 | 07:19 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Without knowing which engine it is hard to say. Most common would be one of the dry sump engines where they only drained one of the two drain plugs and then put in the full amount of oil leaving it way over filled. "put the oil in the wrong hole" might also indicate that it is a dry sump because the normal oil fill cap is sealed and has to be broken to get it open. The proper fill location is the dry sump tank in the rear on the passenger side. But this all assumes you have a dry sump engine. If not then
As far as a large dealer selling lots of Corvettes not knowing how to change the oil in one without destroying it, that doesn't surprise me at all. I have never been to a dealer that knows the first thing about maintaining a Corvette. I went to a large dealer selling lots of Corvettes and the first thing they did was break the rocker panels because they didn't even know how to put it on the lift.
Old Jun 4, 2014 | 07:57 AM
SCcues's Avatar
SCcues
Pro<br><img src="/forums/images/ranks/500-1000.gif" border="0">
Default Oil change?
I'm not a young man anymore and for years it was easier to take my car (not a Corvette) in and let someone else do the oil and filter work. Well the largest Chevy dealer and the Lexus dealer took advantage of me and charged for work they didn't do and tried to get me to pay for work not required. I told myself when I got my Corvette that if there was anyway I could do the work myself I was going to do it. I do my own regular maintenance and I have peace of mind knowing that it's done right!
Work like oil changes in large shops usually goes to the least experienced men so things like the OP described can happen. How in the world do you put the oil in the wrong hole?
Old Jun 4, 2014 | 08:30 AM
papadr's Avatar
papadr
3rd Gear
Originally Posted by Triumph Jerry
What is the car?
Sorry I am a " newbie". It is a GS in red. Model LT4 ,manual with dry sump.
Old Jun 4, 2014 | 08:39 AM
EVRose's Avatar
EVRose
My guess is they didnt drain it properly and over filled it. Not the first time (or second or third) I've read about a dealer doing this.
Old Jun 4, 2014 | 12:49 PM
Cratchet's Avatar
Cratchet
Lots of stories on this forum where they hydrolocked it because they overfilled it. I'd be asking a lot of detailed questions about what occurred.
Old Jun 4, 2014 | 01:40 PM
HOXXOH's Avatar
HOXXOH
Thick white smoke is a strong indication of a broken block/head caused by the oil change screwup. They'll be buying you a new engine.
Old Jun 4, 2014 | 02:49 PM
papadr's Avatar
papadr
3rd Gear
I just went to pick up my car and spoke to the mechanic who had worked on it.He admitted he put the oil in the normal fill cap.He said he was easily able to turn the cap ,which is suppose to be locked shut.He then started the car and saw the smoke.Got help from a supervisor who told him about the dry sump .
They then emptied all the oil and filled it properly through the sump.The car was never without oil,so I think the white smoke was from the extra oil burning in the chamber.I will get a letter from the company confirming their mistake in case I have problems later on.
Appreciate all the replies.
Dave
Old Jun 4, 2014 | 04:18 PM
iclick's Avatar
iclick
That's why I've done all my own oil changes for the past 50 years for my cars, motorcycles, and lawn equipment--and that goes for anything else I can reliably do myself.
Old Jun 4, 2014 | 06:25 PM
VET4LES's Avatar
VET4LES
I'm the only one I can trust.
Old Jun 4, 2014 | 06:27 PM
HOXXOH's Avatar
HOXXOH
Dave
Oil smoke is blue, but white smoke is water/antifreeze. You don't get white smoke unless something broke to allow coolant into combustion chambers.
Drive it hard for a few days and keep close track of oil and coolant temps along with oil pressure and volume. If it breaks even farther real soon, there will be little doubt that the oil change error was the cause.
Old Jun 4, 2014 | 06:35 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Frankly, I doubt you spoke to a "mechanic" with any knowledge of C6s, but you were at a dealer that services/sells a lot of Corvettes! Now you know that counts for nothing.
I'll tell you how little it counts for: one of the two dealers in my area that has good Corvette-certified technicians (there are more than two dealers who sell Corvettes) decided to take away the oil changes by Mr. Goodwrench oil changers, and put it with the Corvette team that ARE the hotshot Corvette-certified technicians. Only them. If they screw up a simple oil change on a GS, Z or ZR compared to a base model, it will be ALL ON THEM since there is no reason for them not to know what to do and do it correctly.
Your car is not a complicated car, but it does have its unique aspects. IMO you are going to have to be a bit more diligent in who services your car, and whether you're there to watch or not.
Good luck with getting that letter; I hope you never need to use it.
Old Jun 4, 2014 | 08:13 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
Dave
The cap IS NOT LOCKED SHUT. It is held with little plastic clips that are easily broken upon opening. So, I wouldn't be surprised if you have little pieces of plastic in the valve train. If you bought the car used it is possible that the tabs were already broken. But if the mechanic broke them he could have felt them break and he is lying to you to protect himself.
Burning a little oil gives blue smoke, however burning a lot of fresh oil gives you a blueish white cloud of very thick smoke that smells like oil. I used to have a jetboat with a 455 Olds in it. At the end of the summer I would start it and pour1 qt of fresh oil in slowly until it died. This would produce a cloud of heavy whitish smoke. Next summer I would start it and it would smoke for about 5 minutes.
Good luck...
Old Jun 4, 2014 | 08:19 PM
saplumr's Avatar
saplumr
Not necessarily. I had 2 60# fuel injectors stick wide open and it was a complete white out behind me. Just one of those little things I found out.
To Help with engine issue
Old Jun 4, 2014 | 08:24 PM
Huskerman's Avatar
Huskerman
2021 C6 of the Year Finalist - Modified
Document everything and everyone involved.....you will need it if you have to go to Chevy Corporate....
Old Jun 4, 2014 | 09:00 PM
Jawnathin's Avatar
Jawnathin
Do compression check and/or coolant pressure test. Make sure its on their dime.
This will hopefully tell you whether or not there has been any compromise in the block or cooling system.
Old Jun 5, 2014 | 02:03 AM
HOXXOH's Avatar
HOXXOH
Thanks. And now it's something I learned too.
