Gas Cap Problems!!
Yesterday I took my (2005) car to our club picnic. I drove it about 150 miles in all. I got home last night about 9:30 and I stopped my car in front of the garage, got out and opened the garage door. When I get back into the car, I notice the engine light is on. Uh-oh!!
Oil pressure is good. Temperature is good. So I pulled it in the garage and shut the engine off. Start it up again- same thing, engine light on. -------I got out my manual and read: The light can come on if I recently put gas in the car. Ah-hah!! I had just filled it up earlier in the day. But how do I get the light to go off?
-------Then I came out this morning read that the gas cap could be on improperly. No, it couldn't be that. The gas cap was new last fall. And I was always told to put the cap on ever so lightly. It always worked perfectly before this with the cap on slightly.
--------So, I took the cap off, put it back on a few times and I got the same thing. Then I put it on and gave it about three spins. Bingo!! The light goes out. So now, after putting it on lightly all this time, I am going to have to put it on tight to keep the light from coming on. Oh well. At least the light has gone out.......for now.
Yes, there was a TSB for the fuel system that included new software for the BCM because the level sensor "debounce" timing was too short. It allowed for a longer period of failure of a level sensor before declaring a fault and setting a code.
But, OP, you didn't get the gas cap message on the DIC. You just found something in the manual that said it COULD be the gas cap among the hundreds of other possibilities for a Check Engine Light. Why assume it was the gas cap at fault? Maybe (probably) it was but without reading the codes there is no way to tell for sure. Let us know if the issue returns and don't go spending a lot of money trying to fix a fuel system issue when it could be something as unrelated as a wheel sensor or oil sensor or...
