Splitter Differences? Clearance?
Old Dec 26, 2014 | 01:02 PM
Tefer's Avatar
Tefer
I installed the Z-RAL splitter on my G/S a couple of months ago, I also have a sloped drive. Have not driven much since installation but have pulled in and out of the drive a few times just to check it out. I still pull in or out at a pretty good angle and so far have not scraped. no doubt it does increases clearance in the center. I think on RPI'S web site states the corners are about 1/8'' lower than the G/S stock splitter. Any way I love the looks, Defiantly a great addition to my G/S and the color match is perfect.
Old Mar 23, 2015 | 07:42 PM
PDsVettes's Avatar
PDsVettes
I just received the ZRAL splitter from RPI. I tried installing it today and I think that I might have a problem. I removed the outside air dams on both sides and dry fit the splitter. It does not cleanly lay in place. There are three tape areas, one in the middle and on each end where it wraps around the corners of the bumper. With the two outside ends and the middle section of the splitter touching the bottom of the bumper cover, there is about an inch of space on the inside tape attaching points where the two cutouts are located.
Did you guys have this same issue? Did you just press the splitter hard enough up against the bumper cover to close the space up and then install it with the tape and screws?
The issue to me is that it does not just cleanly lay into place so that you can use the tape and screws to secure it easily. I'm wondering if I have a problem with the bumper cover. I noticed that the two fangs are pretty well scraped. Could this be bent up? If it is, can it be bent back into its proper position or does this part need replacing? I don't even know if bent fangs would cause bumper cover to not fit correctly.
I'm doing this by myself so I can't provide any pictures.
Old Mar 24, 2015 | 08:50 AM
Yellogixxer's Avatar
Yellogixxer
Are you sure you have the correct splitter? It looks like you have a base coupe but sounds like you have the splitter for the wide body.
Old Mar 24, 2015 | 01:41 PM
PDsVettes's Avatar
PDsVettes
I don't know how you would tell the difference unless you have one of each for comparison. The pictures on the RPI site for either the base coupe splitter or the Z06 splitter do not look like the splitter that I have. The basic design is the same but my splitter has a dog ear on the inside curvature at each end for a mounting screw.
I just got a reply from Josh at RPI. He said that I needed to start at ends, aligning them with the wheel wells and work towards the center. I'll for sure get someone to assist me this next time I try to install it. It will be a couple of weeks as I am going on a trip.
Old Mar 24, 2015 | 02:18 PM
LS1DIME's Avatar
LS1DIME
Like another member posted a few posts back I have the C7 Carbon ZR1 Carbon Fiber Splitter and was surprised to find that unlike my stock Z06 Splitter it does not drag exiting my garage. The Stock one drug every time, the ZR1 style has not touched my driveway yet!
Old May 7, 2017 | 01:30 AM
whitleyred's Avatar
whitleyred
Default Zral front splitter
Originally Posted by long_tall_texan
I have a ZRAL-1 splitter from RPI that is going g on my Z06 next week. I'll be happy to take pics and clearance measurements as soon as the body shop gets done painting and installing it. Supposedly, the cut up in the center actually gives you more ground clearance than OEM Z06 or GS front spoiler.
the front Zral splitter comes painted I ordered mine from Southern because I ordered mine black
Old May 7, 2017 | 01:35 AM
whitleyred's Avatar
whitleyred
The front Zral splitter I ordered mine from Southern car parts and I had them paint it black mine is going on a Precision red 2005 Corvette base body, I will also like to see the pictures of yours when you have yours install.
Old May 7, 2017 | 11:19 AM
long_tall_texan's Avatar
long_tall_texan
Old May 7, 2017 | 03:13 PM
whitleyred's Avatar
whitleyred
Default Wow!
wow! That's a really nice zral front splitter, seeing this picture makes me really happy that I ordered mine, thank you for posting..
