Trunk/hatch button question
Old Jul 5, 2014 | 12:01 AM
jsucraig's Avatar
jsucraig
If you just took the button off, which is what the description of what you found would lend me to believe, you can also actually split the switch body about half way up. That is where the corrosion that I posted about finding earlier actually lives.
I did the same thing right after I bought my 2013. The date code was 2005 on the switch in my 2013 Grand Sport. It must have been on the shelf for quite some time. There was some grit and grime in mine. I cleaned it out, reinstalled it, and tested it. The switch worked two or three times and quit. I thought I'm going to take it apart and see what the condition of the actual contacts look like. What the hell if I break it they are around $20 bucks with shipping. So I did and the contacts were literally green with corrosion. I used some 400 grit sand paper to clean them up. Then I applied some dielectric grease, reinstalled the switch, and then voila it works like a charm.
Here is the link at GM Partshouse: Base Grand Sport Both $17.71+Shipping
Most likely the same switch. There should be no difference. Especially since I believe that the same switch was used on C5 as well. Probably why the date code on my switch is 8 years older than the car itself.
Old Jul 5, 2014 | 10:07 AM
richietables's Avatar
richietables
Thanks, jsucraig---
I just ordered the new switch and we'll see how it goes. Have a couple of big road trips coming up and I'll be happy if the button works again. If not I'll get into the switch and try what you said.
Thanks for the info and the link.
Old Jul 5, 2014 | 11:07 AM
anarchy67's Avatar
anarchy67
Originally Posted by EVRose
wd40.
wd40 is not good for locks. graphite powder is best.
Old Jul 5, 2014 | 11:24 AM
EVRose's Avatar
EVRose
Are you a locksmith? THIS guy is.
Old Jul 5, 2014 | 10:03 PM
anarchy67's Avatar
anarchy67
He may be a locksmith but he is also a moron. If being able to pick locks and cut a key from tumbler marks makes you a locksmith then yes I am a locksmith too. However any lock manufacturer will tell you not to put wd40 in your cylinder. First because they use a teflon lubricant at the factory and mixing lubricants will gum up the tumblers.(much like mixing snyth oil with traditional oil) Lock manufactures also have their own lubricants they trademark. All that aside liquid lubricants will trap more dirt inside in a dusty environment so what seems like a quick fix is actually going to make it worse in the long run. In closing No I am not a locksmith but I don't throw an opinion out there unless I know WTF I'm talking about. Graphite powder is best for locks. If youve screwed it up so bad that it wont help Then a teflon spray would be best followed by a flushing with degreaser after its worked loose, then the powder.
Old Jul 12, 2014 | 12:09 PM
richietables
Not going to be drawn into the locksmith/WD40/moron thing!
New trunk button just arrived this morning and two minutes later it was in and working--
Thanks again, guys...
Old Jul 12, 2014 | 12:17 PM
jsucraig's Avatar
jsucraig
Glad the new switch worked out for you. Now clean the other up and keep it in the glove box with a T15 Torx Screwdriver. The next time it gets gunked up slap the other in real quick and off you go.
