Diminished Value
Old Jul 15, 2014 | 04:56 PM
LbulletM's Avatar
LbulletM
Default Diminished Value
How much less would you pay for an LS2 Corvette that has been in an accident and sustained $12k in damage?
Old Jul 15, 2014 | 05:01 PM
wayback's Avatar
wayback
If I knew of the damage I would run away.
Old Jul 15, 2014 | 05:02 PM
z28lt1's Avatar
z28lt1
I think the issue you'll have is that many people won't buy it all. Too many other options.
Also, details on the damage are important, and you don't list what specifically was damaged.
There will be some buyers at a slight discount I would imagine, I would wild-guess 1-2k less than the price otherwise, but much smaller pool of buyers.
Old Jul 15, 2014 | 05:07 PM
v26278's Avatar
v26278
As a rule of thumb, assuming no frame damage, and repaired properly with supporting documentation, knock 50% of the cost of the repairs off the fair price of the car if it were never damaged. $6K in your case.
Old Jul 15, 2014 | 05:14 PM
R&L's C6's Avatar
R&L's C6
Old Jul 15, 2014 | 06:02 PM
LbulletM's Avatar
LbulletM
Driver's side: Replaced fender, door panel, quarter panel, wheel, tire, A pillar plastic, control arm, tie rod, markers
Passenger's side: Fixed fender, replaced wheel and tire
Bumper: Replaced bumper and emblem
Old Jul 15, 2014 | 06:16 PM
Dank27's Avatar
Dank27
Originally Posted by R&L's C6
+1 sorry too much inventory
Old Jul 15, 2014 | 06:19 PM
ButWhatDoIKnow's Avatar
ButWhatDoIKnow
Run, don't walk, away.
Old Jul 15, 2014 | 06:28 PM
Wildmanht's Avatar
Wildmanht
That seems like way to much damage to consider the car. At least I wouldn't buy it.
Old Jul 15, 2014 | 06:30 PM
awschucks's Avatar
awschucks
Default Repaired ride
I see no problems with buying a car that has been damaged and repaired professionally. Even if there is some frame damage, if it is repaired properly it will be a good car. Rustproofing of any frame damage and using factory panels brings the car back to original.
I have repaired C2's thru C6's and am very comfortable driving any of the cars that I have worked on. Lately, it's getting easier to buy original color matching panels so no painting is involved. While I am **** to get the right screws in the correct places and my panel lines are better than factory, some people do sloppy work. Check the car for workmanship.
Just for the fun if it, I would like to offer a challenge to other owners. Go out and measure the wheel base on the right side of your car and then on the left side. Even if you have not had damage, you will find that most Corvettes do not have the same wheel base on the right and left from the factory. When a good frame shop is done with a car the wheel base will not only be correct on the left and right, but will also be measured in the X dimension and be correct.
Old Jul 15, 2014 | 06:35 PM
Cybernetic Medic's Avatar
Cybernetic Medic
I would consider a car like that if I knew the owner and knew the repairs brought it back to like new condition, it was exactly what I was looking for as far as options and colors, and I planned to keep it for a very long time.
Old Jul 15, 2014 | 06:43 PM
Kenny94945's Avatar
Kenny94945
I'm with above...would not buy.
50% of low book and I would still not buy.
That vette had some damage.
Then there is the hidden or unrepaired damaged.
Old Jul 15, 2014 | 07:23 PM
phileaglesfan's Avatar
phileaglesfan
It would have to be substantially discounted for me to even consider it. I don't care who repaired it. Most people wouldn't consider $2-3k a break on a car that is around $30k. If the undamaged one is the same exact car then most people would pay $2-3k more.
Old Jul 15, 2014 | 07:27 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Run Forrest, Run !!!!
Old Jul 15, 2014 | 08:37 PM
raspyc6's Avatar
raspyc6
^yes...but I will play Devil's Advocate. The guy has ZERO structural damage to his car so as far as looks and does it shoot straight? Yes. To that extent, in this case, the difference is just not all the body panel numbers match. But now you are having new GM body panels painted to match. You will not notice a damn bit of difference and MA?Y?BE it drives just a bit better afterward, feels a little tighter maybe. Would I ever wanna buy a wrecked vette or any car? Of course not but here is my post from the perspective of a person who just would jump in and drive without hearing history.
To the OP how much diminished value?... I have no idea as I am not an adjuster. From a driver's perspective I offer you the hope she drives even better. cheers
Old Jul 15, 2014 | 09:27 PM
bobeast's Avatar
bobeast
My wife hit a cat in my 97 a while back and cracked the front fascia. I found a new replacement and had it painted to match.
The new fascia has zero rock chips, perfect paint and aligns with the adjoining fenders better that it did from the factory.
Is this a damaged car or an improvement? The point being, I wouldn't knee-jerk and run away. I'd get the facts of the particular circumstances and make an informed decision. If it was repaired properly, its likely in better shape than the rest of a car with any miles on it.
Old Jul 15, 2014 | 09:55 PM
not08crmanymore's Avatar
not08crmanymore
OK,ever hear of apples to apples? Because this ain't it.
With all the CORVETTES out here in pristine condition or close,why even bother considering a wreck of a car like this one? 12 grand in damage is a whole lot of parts and pieces and what's worse the stigma and having to explain to everybody when you might want to sell it what the damage was.I wouldn't even let this car on my block with that kind of damage,repaired or not!
To Diminished Value
saplumr's Avatar
saplumr
The facts are $12K in repairs. He didn't run over a cat unless he hit two trees in the process!!
Old Jul 16, 2014 | 08:41 AM
dvilin's Avatar
dvilin
Nothing.
Old Jul 16, 2014 | 08:50 AM
rbell's Avatar
rbell
Consider resale problems when you go to sell it in the future, both value and the same questions and replys you are getting right now.
