Storage ?
Old Aug 18, 2014 | 07:24 AM
69L68's Avatar
69L68
Default Storage ?
It appears that will be storing my 06 vert M6 for about 6 months in a cold climate. I have a Battery Tender but I am curious to what else I should do. Any tips would be helpful.
Thanks,
Steve
Old Aug 18, 2014 | 07:30 AM
IDSRVIT's Avatar
IDSRVIT
Thanks,
Steve
Battery Tender, fill up tires to 35 psi and for critter control, put downy dryer sheets all over the inside of the car, under the car, and in the engine compartment, and cover it up is all that I do.
When you take it out of storage hold the accelerator down while cranking the engine to get the oil flowing and then let off the accelerator and she'll fire right up.
Been doing this since 08 without any issues.
Old Aug 18, 2014 | 07:53 AM
Z51vette88's Avatar
Z51vette88
Old Aug 18, 2014 | 08:08 AM
69L68's Avatar
69L68
Thanks. It won't be as cold as South Dakota (I hope), but its my first time long storing.
Steve
Old Aug 18, 2014 | 08:21 AM
IDSRVIT's Avatar
IDSRVIT
Steve
Probably comparable since mine is now stored in a heated garage (temps in the 50s).
I did do one year in an unheated garage where the lowest temps that winter was -27F and it still did fine.
Old Aug 18, 2014 | 08:29 AM
myfunz's Avatar
myfunz
Thanks,
Steve
Will the car be inside or out? A nice car cover would help.
Old Aug 18, 2014 | 08:50 AM
purvistechie's Avatar
purvistechie
Thanks,
Steve
As someone who is storing something all the time (for summer or winter), Wash, Full tank of gas, STA-BIL, Oil Change, battery tender and cover.
Old Aug 18, 2014 | 08:59 AM
Don-Vette's Avatar
Don-Vette
This is what I do...
Clean car inside and out with fresh wax.
Inflate tires an extra 3-4lbs.
Check all fluid levels.
Fill gas tank with a bottle of Sta-Bil.
Connect battery maintainer.
Put cover on until Spring.
Old Aug 18, 2014 | 09:03 AM
Z51vette88's Avatar
Z51vette88
What does downy sheets do?
Old Aug 18, 2014 | 09:17 AM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
Cover your exhaust outlets to keep rodents out. Otherwise they'll nest up in your exhaust system.
Old Aug 18, 2014 | 04:31 PM
Bruze's Avatar
Bruze
I'm assuming they're "the new" mothballs . . . ?
Old Aug 18, 2014 | 04:44 PM
IDSRVIT's Avatar
IDSRVIT
Correct.... and for what ever reason only downy works. I had two friends who gambled on an experiment with their campers 4 years ago to solve an arguement that brand didn't matter and one used downy sheets the other used generic sheet in their campers. They were parked right next to each other in the rental place lot. In sprint time when it came to take them out of storage the one with downy had no mice anywhere and the one with generic sheets had mice still crawling around inside when he brought it home. He spent the next month replacing cushions, carpet, cleaning, etc.
I've used downy ever since.
Old Aug 18, 2014 | 04:51 PM
Red08's Avatar
Red08
As others have said...change the oil & filter, add an extra 3-5 psi in the tires, use a battery tender, fill it with fuel and use a fuel stabilizer, cover it up and it should be fine. I have mine in winter "storage" for 3-4 months every winter and once I am ready to take it out in the spring, it is ready to go.
Old Aug 18, 2014 | 05:24 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
You might also consider using jackstands to avoid flat spotting the tires.
Old Aug 18, 2014 | 05:32 PM
Bruze's Avatar
Bruze
Interesting, thanks.
Also: when adding fuel stabilizer, be sure to run it a few miles so it gets into the entire fuel system.
Old Aug 18, 2014 | 05:34 PM
R&L's C6's Avatar
R&L's C6
I read somewhere it's not good for your suspension to "hang" for months on end. I have been storing my car for five to six months at a time without any sign of the tires flat spotting.
Old Aug 18, 2014 | 06:20 PM
dvilin's Avatar
dvilin
I agree been doing it this way since 2008, no issues when ready to fire it up in the Spring.
To Storage ?
Old Aug 18, 2014 | 06:21 PM
IDSRVIT's Avatar
IDSRVIT
I've read that too...... also tires today rarely flat spot.
Old Aug 18, 2014 | 09:14 PM
Larry/car's Avatar
Larry/car
Already we are talking about storage, it is August (I know it doesn't feel like it).
Old Aug 18, 2014 | 09:20 PM
Bruze's Avatar
Bruze
It didn't get above 62 degrees INSIDE my house on Saturday. I had to light a fire that evening. I've never done that in August before.
I dread what this winter will bring.
