Digital information Center
Received 1,137 Likes
FWIW: I have the original owner's manual, plus I have an online version. The online copy is much more useful than the hard copy. You just enter keywords and search for them. No need to thumb through an index covering 500 pages.
See if this is what you're looking for.
Personalize Name: This option
allows you to type in a name or
greeting that will appear on the DIC
display whenever the corresponding
RKE transmitter (1 or 2) is used or
one of the memory buttons (1 or 2)
located on the driver door is
pressed.
Press the OPTION button until
PERSONALIZE NAME appears on
the display, then press the RESET
button to scroll through the following
modes:
. YES
. NO (default)
If you choose YES, you can type in
a name that will appear on the DIC
display.
To program a name, use the
following procedure:
1. Enter the PERSONAL OPTIONS
menu and select the driver
number (1 or 2) that you would
like to program by following the
instructions listed previously
under “Entering the Personal
Options Menu”.
2. Press the OPTION button until
the PERSONALIZE NAME
option appears on the display.
3. Select YES under
PERSONALIZE NAME by
pressing the RESET button.
4. Press the OPTION button and a
cursor will display where you
can insert a letter.
5. Press the OPTION button again
until the letter you want is
displayed. To scroll through the
letters faster and without a
beeping noise, keep the
OPTIONS button depressed.
There are alpha/numeric
characters and a blank space
available
6. Press the RESET button to
select the letter of your choice
and proceed on to the next
space to the right.
If you make a mistake and would
like to clear or replace a letter,
perform the following steps:
6.1. Press the RESET button to
reach the letter you would
like to change.
6.2. Press the OPTION button
to scroll through the letter
choices.
6.3. Press the RESET button to
select the letter and
space to the right.
7. Repeat Steps 5 and 6 until the
name or greeting you want is
complete. After the name or
greeting is complete, keep
pressing the RESET button until
the display turns blank and exits
out of this option. You can
program up to 20 characters.
If you choose NO, this option will
turn off.
If a customized name or greeting is
not programmed, the DIC display
will show Driver 1 or Driver 2 to
correspond with either the
number on the back of the RKE
transmitter (1 or 2) being used or to
the memory button (1 or 2) that is
pressed.
PERSONALIZE NAME is the last
option available to program in the
PERSONAL OPTIONS menu.
Pressing the OPTION button after
this setting will exit you from the
The last item you were in prior to
entering PERSONAL OPTIONS
will then display on the DIC.
pressed.
modes:
. YES
. NO (default)
display.
Options Menu”.
3. Select YES under
PERSONALIZE NAME by
available
space to the right.
like to change.
choices.
space to the right.
turn off.
pressed.
Starting here - http://forums.corvetteforum.com/c6-c...questions.html would certainly be worth your time and effort. Start by getting a manual. There's a LOT more top these cars than just setting the DIC message.
