Gas Cap
Old Sep 7, 2014 | 11:58 PM
USA1 427's Avatar
USA1 427
Default Gas Cap
Buying gas today and the gas cap wouldn't lock when I was done. Not the door, but the cap. It would turn and click, but kept falling off. Took at least a dozen tries to get it to hold. Anybody else have that happen? How did you fix it?
Old Sep 8, 2014 | 12:24 AM
Gering's Avatar
Gering
Tolero Apto Victum
I replaced mine with one of these -
Amazon.com: Stant 10504 Locking Fuel Cap: Automotive Amazon.com: Stant 10504 Locking Fuel Cap: Automotive
Old Sep 8, 2014 | 07:19 AM
GrayGrandSport's Avatar
GrayGrandSport
I have had the same issue occasionally but so far it has finally clicked into place after a few tries. It's still under warranty for another two years so if it gets worse I will let GM give me a new gas cap.
Old Sep 8, 2014 | 07:59 AM
09Z06pj's Avatar
09Z06pj
Veteran: Marine Corps
Don't apply any pressure when turning.
Old Sep 8, 2014 | 01:31 PM
vetteguy4's Avatar
vetteguy4
Mine just started doing that. Had to turn it several times before it locked into place. Car is still under warranty so will have the dealer replace it.
Old Sep 8, 2014 | 02:35 PM
Mikado463's Avatar
Mikado463
same thing here, check engine light came on alerting me to the problem……….
Old Sep 8, 2014 | 03:04 PM
wrh3's Avatar
wrh3
^^^ This, hold it loosely while turning until it clicks a few times, it is counter intuitive but works.
Old Sep 8, 2014 | 03:47 PM
Jose2SS's Avatar
Jose2SS
Happened 2 weeks ago, replaced it and no problem. Looks like those gas caps are weak.
Old Sep 8, 2014 | 04:16 PM
jversluis's Avatar
jversluis
Same problem, went to dealer today and they replaced. Seem to be a few gremlins in these 427s'. Im chasing a clicking in steering when moving back and forth. they already replaced the rack which it fixed for a week. now dealer is checking with GM to see what to do next.
Old Sep 8, 2014 | 11:42 PM
USA1 427's Avatar
USA1 427
Dealer replaced the cap today under warranty.
Old Sep 8, 2014 | 11:47 PM
Gering's Avatar
Gering
Tolero Apto Victum
Good to hear - thanks for the update.
Old Sep 9, 2014 | 01:11 PM
kimdjay's Avatar
kimdjay
Rather than pushing in and turning it to lock (click), I put it in and turn it a bit, then PULL it out while turning it to click.
Old Sep 9, 2014 | 01:15 PM
not08crmanymore's Avatar
not08crmanymore
There's a 10 yr -120,000 mile warranty on it just in case since it's been happening since 2005.However,when I thought mine was bad on the '13,I saw the "don't apply pressure" thing and since then it locks in place normally with pushing to hard on it. Give it a shot.I will say that if it's broke,the one they replace it with under warranty will break too...went thru 3 or four on my other vettes.
Old Sep 9, 2014 | 02:28 PM
Mikado463's Avatar
Mikado463
isn't it amazing that GM can't get such a simple thing as a gas cap 'right'
FWIW, my previous company vehicle ('06 Impala) was on it's fourth cap @ 125,000 miles.
I was told that ethanol gas was part of the blame ……..
Old Sep 9, 2014 | 02:51 PM
cclive's Avatar
cclive
Originally Posted by Gering
I replaced mine with one of these - Amazon.com: Stant 10504 Locking Fuel Cap: Automotive
I did this also but mine called for a 10511. $10 and no worries.
Old Sep 10, 2014 | 12:39 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
USA1 427,
Thanks for your update! It's great to hear that the dealer addressed your gas cap concerns and now service is complete. Please let us know how the vehicle operates moving forward and don't hesitate to message us if any additional questions or concerns arise.
William R.
Chevrolet Customer Care
Old Sep 10, 2014 | 11:17 PM
Move Over's Avatar
Move Over
Ditto here. Had mine replaced under warranty and no problems since.
To Gas Cap
Old Sep 11, 2014 | 04:15 AM
Dano523's Avatar
Dano523
FYI, the gas cap on the vet is warrantied for 10 years, 120K miles.
If you get any grief from the dealer on a free replacement, have them check # EIO7238 for the replacement cap, which even covers their time changing it out.
Also, if you do need to take the car in to have them replace the gas cap, do a quick recall search on your car encase their is something else the need to deal with while you are there.
https://recalls.gm.com/#/
Old Sep 11, 2014 | 08:09 AM
Judgebull's Avatar
Judgebull
My GS13 started having gas cap problems last week. I drove the car and the next time I started it the info "check gas cap" flashed across the screen. I wiggled, pushed, pulled turned and it finally sealed. I guess a trip to the dealer is in order. Good to hear its a fairly common problem.🇺🇸👍🏁💸🇺🇸
Old Sep 11, 2014 | 09:08 AM
SCcues's Avatar
SCcues
Pro<br><img src="/forums/images/ranks/500-1000.gif" border="0">
Default Gas Cap
I had the same problem with my 2012. When I bought the car I had to buy gas to get home after doing all the paperwork at the dealership and it was late and near dark. I went to a gas station near the dealer and I couldn't get the cap to close like my other cars. I had never had a gas cap issue before and I ended up turning it just enough until it made contact and I guess that was ok. I like to feel my cap tighten up, but the Corvette cap won't do it. You have to go easy when it gets tight because if you turn it hard it will come loose.
