Please help me decide!!!
Old Sep 13, 2014 | 10:10 AM
C6Racer1083's Avatar
C6Racer1083
Default Please help me decide!!!
Hello everyone and thanks for your time. Here is what I am thinking of doing/getting.
So I have a 30-35K dollar limit on a corvette giving by the wife. I also have about 20k plus to put into the car and don't mind using part of that 20K to purchase a nice Z if that's the way I decide to go. I want either a base C6 with nav and all that or a C6Z with the same. I like the removable roof on the base, but also like the looks of the Z as well as the performance.
I am wanting to push around 800 plus rwhp out of either of these cars. From what I have read and been told that the Z06 sucks for supercharged applications. I have seen several threads about them being supercharged and seem to be fine. I will be driving this car about 3 to 4 days a week and will not be taking it to the track much at all. I want to supercharge, stroke and run meth plus more on either one that I decide.
I am somewhat new to corvettes being have only owned a C6 Base. Sorry if this seems dumb. Sold it and do I regret that one.
Thank you for your time and I look forward to hearing opinions!
P.S Currently deployed and doing my research.
Last edited by C6Racer1083; Sep 13, 2014 at 10:22 AM. Reason: Forgot to add to the post
Old Sep 13, 2014 | 10:30 AM
LedZepper's Avatar
LedZepper
Because you like the looks of the ZO6, your price range and would like a removable roof, a Grand Sport may be right for you. I've read that there's some excellent supercharger options for the LS3. Good Luck!
And also, thank you for your service. Hope you can come home soon.
Old Sep 13, 2014 | 10:34 AM
24/Eray's Avatar
24/Eray
800 plus rwhp? not on that budget. you would have drop down to a low 20k c6 which unless you find the deal of the century (i did after almost a year lol) it will not be an LS3 car and most certainly not have all the options you are looking for. furthermore, if you are going to use it as a daily driver (just about?) that hp number is unrealistic for any daily driver unless it cost you HUNDREDS of thousands of dollars..
What does it matter how much hp you laid down on a dyno? do you have a goal other than bragging rights on a dyno? like a mph in the 1/4? or an et?
if i had your cash and your goals minus the ridiculous 800+ hp number i would buy an '08 3LT with F55 (most comfortable/controlled ride in a c6) with high mileage but not beat to death, change the headlight lenses, windshield, steering wheel, center console lid and anything else that has wear to it within reason. have someone with a GREAT reputation build your LS3 (416 stroker) and drop any supercharger you deem appropriate on the top. even with that you're probably 10k short on your budget. either one or the other
i had a stroker, nice but I would go heartbeat TVS or edelbrock for my next engine upgrade.... runs like stock but there when you want it.. best of both worlds.
you didn't mention stick or auto either? stick easier to build auto? not so much.. in that case you may need to convert to 4l trans. and the rear will need beefing up also or you'll be snapping axles left and right if it hooks (which btw it won't lol)..
best of luck, but that budget would be tough. realistically you could get a nice C6z and some bolt ons and call it a day.. but i wouldn't want to drive a c6z almost daily unless you live in a place where roads are GLASS smooth.
And if you want the removable top? get a GS and drop a pro-charger in it or whatever SC you want.. plenty fast and will be very reliable.. but you should seriously contemplate the F55 for a daily.
Old Sep 14, 2014 | 06:05 AM
C6Racer1083
Ledzepper my Pleasure to serve our country! Thank you.
Also, Tonygxp What is a realistic HP number for a daily driver? I just threw out 800 hp because I see a few lambo's around Nashville and figure I need that to beat them. LOL
I plan on buying a six-speed by the way.
Old Sep 14, 2014 | 06:52 AM
08C6's Avatar
08C6
Pretty sure what would work for you on that budget !!! buy a GS - supercharge it - header package ... Cam swap would be good but not necessary ... There a lots of knowledge on this forum - but I will tell you from my experience on what I have - 08 base Coupe 3LT - automatic I have done the Magnuson Heartbeat unit - LG Motorsports header package - Borla exhaust ... I really don't have crazy insane numbers !!! 565 RWHP - 535 RWTQ which I think is crazy for the street - way enough power... Maybe your goals sound like 600 - 625 RWHP... which would be pretty crazy... I also wanted to build something - somewhat very reliable and safe ... Good luck on your decisions here..
Old Sep 14, 2014 | 07:42 AM
high9s's Avatar
high9s
OP, this is just my opinion, I would try to find an 08 Grand Sport, the LS-3 and the dry sump are a great combo, and made for boosting.
I have an 05 (which I don't recommend) The LS2 is also a great engine 06 and 07 would be a better choice if you went that route, I had to change my rear, trans, and half shafts to stay reliable. Don't forget to add a clutch to your build, you will smoke the stocker in short order.
My big suggestion is if you are going with a stock bottom end, start with lower hp, I make between 620-640 rwhp depending on the dyno I'm on. I know there are faster cars out there...I just haven't found one yet I run a big fat tune, with no meth on pump gas can sit in traffic for hours in 90 heat and have done 1000 mile road trips.
My point is you can have a reliable fast car and stay in your budget or a high maintenance "faster car" (if you can hook 800 hp) that will be a little north of your budget.
Just a thought, I have built a few undrivable C-16 drinking 4 mpg 1000+ hp monsters out of perfectly good reliable cars. I have a shirt that says "if its not broke fix it till it is"
Not knocking big hp guys. Most of those guys in my experience have the money and knowledge to play, and its not cheap. Good luck with your build and stay safe over there!
Old Sep 14, 2014 | 08:26 AM
C6Racer1083
Thanks for all the replies! it sounds like I would be happy with 600-650 rwhp. I know that I wont be the fastest but I would like to be one of the fastest in town. LOL, I honestly forgot to even consider the Grand Sport! I will start looking up those.
Thanks a lot everyone!! Keep all the advice coming. As I said before I am somewhat new to corvettes. Anything is appreciated.
Old Sep 14, 2014 | 08:39 AM
high9s's Avatar
high9s
Remember when you start getting above 600 hp its more about the driver than anything else. also the AWD cars hook and have a ton of nannies and duel disc clutches but the also weigh 3600-4000 lbs to my 3150 lbs. There will always be someone faster than you, but at 600+ hp in a Corvette you can count them on one hand.
Old Sep 14, 2014 | 08:43 AM
not08crmanymore's Avatar
not08crmanymore
Grand sport coupe +
supercharger =
right foot on gas pedal.
hold on.
Old Sep 14, 2014 | 09:40 AM
C6Racer1083
I figured that there would be tons of corvettes with over 600 hp and seems like the Grand Sport is the way to go.
To Please help me decide!!!
