Help
Old Sep 21, 2014 | 09:11 PM
school tester 1's Avatar
school tester 1
Default Help
My DIC options button when pushed the DIC Showes options not available
I put new battery in fob and new battery in car. It's a 2013 GS VERT.
it didn't help. Also when I open the drivers side door the car chimes and won't stop untill I start the car, also the passenger side door does not unlock from the out side or inside unless I push the drivers side door open button. Please help.
Old Sep 21, 2014 | 09:49 PM
RicK T's Avatar
RicK T
You must have grabbed the wrong FOB, one that isn't programmed as either #1 or #2.
Old Sep 21, 2014 | 10:12 PM
Vette_DD's Avatar
Vette_DD
It doesn't matter what fob number is stamped on the fob. If the fob was programmed for the car as fob #3 or fob #4, it doesn't have the memory options.
Old Sep 21, 2014 | 11:48 PM
school tester 1
Thank you, I had a new fob given to me by my dealer and he said the tech programmed it as #3. I will bring the car in and have them reprogram them as #1 and #2.
Old Sep 22, 2014 | 12:37 AM
Vette_DD's Avatar
Vette_DD
That will fix the no memory problem. It will also delete all other fobs besides those 2 from the car.
To Help
