M2W what do I need?
Old Oct 12, 2014 | 10:02 AM
maryvillept's Avatar
maryvillept
Default M2W what do I need?
I have an 07 base coupe with stock exhaust. I want to do the m2w mod. Do I need z06 exhaust or whats needed?
I tried the search tool but couldn't find what I needed for base exhaust.
Old Oct 12, 2014 | 10:06 AM
tennblkc6's Avatar
tennblkc6
you need a bi-mode exhaust of your choice and npp in a box.
Old Oct 12, 2014 | 11:55 AM
maryvillept
Which bi mode exhaust would be the most economical? I'm looking to do this on the cheap.
Old Oct 12, 2014 | 12:07 PM
bill K's Avatar
bill K
I have a set of ZO6 mufflers with the mod done they have 6 inch 3" tubes on them. I installed these on my 2005 sound great it cost $300 to have installed they are cut and done inside need plates welded back on. will sell as is for $250.00 or $350 welded. As I said these are on my car could not be happier very little drone open quiet closed. The open sound is the best.
Old Oct 12, 2014 | 03:17 PM
maryvillept
We have 2.5" exhaust how did you change to 3"? Do the tips still hit out right? And what needs to be welded I'm confused there?
Old Oct 12, 2014 | 04:06 PM
ALS 08's Avatar
ALS 08
You'll need Bi mode mufflers. A Vacuum source to operate them. The M2M controller to activate mufflers.
https://www.corvetteforum.com/forums...-in-a-box.html
Old Oct 13, 2014 | 07:09 AM
bill K's Avatar
bill K
What they did on my 2005 with 2.5" exhaust is cut the Zo6 mufflers about an 1.5" and they used a 2.5 to 3 adapter either clamp or weld to existing 2.5" pipes As I stated these sound great. You would need MTW in a box. exhaust will be open.You could do this later as the exhaust will stay open.
Old Oct 13, 2014 | 07:17 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
NPP in a box is the best around, IMHO. It doesn't work like the factory system where they open and close automatically with engine mode but no one has come up with an economical way to do that. This is next best. Some actually prefer manual operation. ~$200 + ~$1,500 for mufflers.
To M2W what do I need?
