starter
Old Oct 20, 2014 | 06:34 PM
bsr8129's Avatar
bsr8129
Default starter
are there any tutorials on how to remove the start? I need to replace mine and i cant seem to get it out, and im hoping I dont have to remove the exhaust to get it out.
Old Oct 20, 2014 | 09:07 PM
cclive's Avatar
cclive
I have heard that that one exhaust pipe needs to be unbolted and lowered, but not removed. The starter is not a difficult job. Someone who has done it will chime in here....
Old Oct 20, 2014 | 10:46 PM
Dano523's Avatar
Dano523
The cat has to be removed to pull the starter.
Old Oct 20, 2014 | 11:04 PM
GhostC6's Avatar
GhostC6
Banned Scam/Spammer
Yes the 2 bolts at the cat have to be removed so it can drop down to get the starter off and the new one on. The bolts are usually rusted and been under high heat. I was taking my loose and thought it was turning pretty well until i realized i had rung it off so be careful and maybe someone can chime in on how to remove the bolts without breaking them like i did on mine.
Good luck. I have a brand new starter if you need one. B&M compact high torque starter, never installed.
Rick
Old Oct 21, 2014 | 03:08 AM
TRUOMEGA's Avatar
TRUOMEGA
You DO NOT have to remove the screws on the catalytic converter to remove the starter. Here is my post on how to do it. Good luck.
Old Oct 21, 2014 | 04:54 PM
GhostC6's Avatar
GhostC6
Banned Scam/Spammer
That link does not work.
Old Oct 21, 2014 | 05:10 PM
Bruze's Avatar
Bruze
^ It did for me.
Old Oct 21, 2014 | 05:59 PM
GhostC6's Avatar
GhostC6
Banned Scam/Spammer
Sorry, I was trying it on my cell phone, it works on the computer..
Old Oct 21, 2014 | 07:57 PM
GhostC6's Avatar
GhostC6
Banned Scam/Spammer
I had a starting issue with my 05 and never did pinpoint the problem. I had a very long thread and for some reason it has been, knock on wood, working fine, I do have a brand new High Torque Compact B&M Starter sitting in the garage in case it does go bad, go look at what all I went through and see if that resembles your and the OP's problem or symptoms. I am curious to see if they are the same or if my problem is different.
https://www.corvetteforum.com/forums...lp-please.html
I am curious if you guys had/have the same symptoms and if I can expect to be installing the starter in the near future.
To starter
