C6 alignment problem
My passenger front could not get a zero toe, the tech said it's likely because that corner has been crashed before (this did not show up on carfax, etc. when i purchased the car). I have been going to this tire shop for years with many of my old cars so I believe the tech.
So these front tires have 500 treadwear rating yet the inner tire for the passenger side is completely gone. such a waste. It's only been about 5000 miles since the tire swap.
So my question is how can I remedy this issue? I would hate to keep replacing front tires.
Camber kit?
A camber kit is not going to fix a toe issue.
Any competent body shop can check the frame dimensions and any reasonably competent shop can check the suspension components.
Hate it when a car becomes a potential money pit but what am I gonna do
Will get a second opinion from a body shop...
I would look for a motorsports shop if your guy is not knowledgeable on the Corvette. Really though, the Corvette isn't all that different/exotic from other cars with upper and lower control arms V.S. struts. The Toe adjustments are just threaded rods with a ball joint in the end, not all that tough to work with.
Having done two camber kits I can tell you they are expensive and usually a challenge for an installer, take time for them to get it right and your normal alignment shop may have trouble with it. I had one installed at a dealer and they didn't get it right, I ended up at at motorsports shop which generally has more experience with different set ups so they are used to thinking "out of the box". When the installer has to sit down and figure out the camber kit, his training is costing you money.
I had a similar problem with an alignment shop. It took an unusually long time for the mechanic to get it done. When it was done, he told me that he was not able to get the caster on the drivers side in spec., so he compensated for it on the passenger side! what the heck? Then he handed me the before and after alignment print out. The after was worse than the before!!!
I high tailed out of that place really fast, took it to someone else who said the alignment was a mess! Everything was out of spec and to top it off, the camber bolts on the front were left loose by the first idiot! I got my money back from the first shop and left a detailed low rating for them on Yelp.
Some mechanics are excellent when it comes to working on other cars, but for some reason Corvette's seem to require an above average level of skill for a mechanic even though it's a Chevy and not really that difficult to work on.
Best of luck to the OP.
I took my car to two alignment shops and both found extreme negative camber in passenger front corner - 1.4 degrees!
I need a shim on my upper control arm, around $150 parts and labor
They also said I need spacers?
Weird thing is before getting new front tires I never had an inner tire wear issue for the last 1.5 yrs owning and daily driving the car...I wonder what happened
Does the above sound like a good solution? Is it safe to modify the upper control arm? If I'm going triple digits, or taking turns at a high speed, any chance of failure etc.? Sorry I'm a suspension noob
Adding or removing shims is how you adjust camber and caster. Toe is changed via the threaded tie rod ends.
I strongly recommend you do a little C6 alignment research online. I have a sneaking suspicion you are confusing terms and measurements. Continuing to do so will result in incorrect advice being given.
Just sayin
NSF
Also, my apologies for the confusion. The shops are all telling me different things.
The first shop told me the toe was off, but apparently it's not, it's the camber (I lost the first shop's alignment printout so couldn't verify). I've had cars with negative cambers before and none of them wore out the inside of the tire as quickly as my car is doing. In my experience toe is what controls if the tires wear evenly or not. Currently my passenger front tire is 80% new on the outside, and the inside strip is basically completely gone. It's ridiculous.
Here is the car's current alignment numbers:
My passenger side control arm is already maxed out, as you can see in the pic below. 2 of the shops are sure it's the bushing that's messed up.
So is replacing the bushings for the control arm the remedy to my problem? One shop said no, 2 said yes.
Annnnndd an added bonus, my front end always had a ticking noise when making turns. I did some testings in my garage to see if it's the wheel bearing, and it didn't seem like it was. A tire shop also said they think it's something loose within the brake caliper. This was a few months ago, and I made a thread with a video in it, but no remedy was found. Well the shop today was pretty sure it's the bloody wheel bearing, but they might be talking out of their *** so will need a more thorough inspection next week if I can manage to find time off from work.
