GS Splitter Question
Old Oct 26, 2014 | 05:57 PM
Bazinga's Avatar
Bazinga
Default GS Splitter Question
I have a 2012 GS that I purchased in June. When I bought the car the center of the splitter had scraped and the connector had pulled through, no big deal at the time.
Well, last night I drove into a gravel driveway and the spiltter snagged and it appears to have pulled out two more of the connectors.
My question is, what is the easiest fix? I am going to order a new splitter tonight, but what is the best way to repair the front facia so I can attach the new splitter?
Thanking everyone in advance for the help..
Old Oct 26, 2014 | 06:55 PM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
As long as you have the pieces that ripped out of the fascia, a body shop should be able to plastic weld them back in.
Or you can buy a new fascia. Could be some other options, I guess
Old Oct 26, 2014 | 07:47 PM
cegusa's Avatar
cegusa
I would think that even if you didn't have the facia pieces that broke, a good bodyshop with plastic welder is still a good option. I would look for a high volume shop that does the plastic repair. They likely have scrap pieces that they could fabricate up for you. Plastic welding repairs usually hold up extremely well if done correctly. Good luck
Old Oct 26, 2014 | 08:05 PM
Bazinga's Avatar
Bazinga
I just removed the splitter and I hope it's as not as bad as I thought.
Found one piece of "paint" about the size of my thunb nail that actually broke off. A couple of the clips attempted to pull through but did not.
I want to thank all on the forum for your help and suggestions, and if any one has any other suggestions they are very much appreciated..
Old Oct 26, 2014 | 08:30 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I wonder what difference it make on the aero, if you just leave the splitter off.
For sure, no difference you could notice under 100 mph.
Above that, I'm wondering.
It would be a bummer to have a GS with worse aero balance than a base model.
Old Oct 26, 2014 | 08:41 PM
Bazinga's Avatar
Bazinga
Gearhed,
My understanding is that the splitter creates a negative airflow that is needed for cooling. I would love to hear from everyone else. I'm sure I'm not the first to drag a GS on the gravel...
Old Oct 26, 2014 | 08:44 PM
Bazinga's Avatar
Bazinga
Gearhead, Thanks for the input. Just read my reply and I did not thank you.. Thank You!!
Old Oct 26, 2014 | 09:09 PM
Gearhead Jim
St. Jude Donor '13
Since we have a base car, I haven't paid a lot of attention to splitters, except that they seem to get damaged a lot.
But on the base car, it's that black rubber air dam, sticking down vertically back under the nose; that is said to help cooling, improve airflow to the front brakes, and reduce front end lift at high speeds. Without a wind tunnel, I can only repeat what others have said.
Best of luck to you...
Old Oct 26, 2014 | 09:33 PM
Bazinga's Avatar
Bazinga
Gearhead, I guess at this point my next project is to construct my own wind tunnel. Man, you talk about fun!!
Old Oct 27, 2014 | 11:20 AM
icntdrv55's Avatar
icntdrv55
I don't think there's anything magic about the exact placement of the attachment clips. If the center one has pulled the clip thru the lower fascia, I'd consider simply moving the screw and corresponding hole a couple of inches either way and creating a new attachment point. Make sure when you're choosing a spot to create a hole for the clip that the point of attachment is clear of body brackets and other things that would interfere. A lot cheaper and simpler than replacing your front fascia.
I've actually thought of adding several more attachment points to the splitter just for security. Seems pretty flimsy--maybe by design?--to hold up to 100 MPH+ wind forces….
Old Oct 27, 2014 | 11:33 AM
C4SMAJ's Avatar
C4SMAJ
I had the ZR1 style splitter 0n my 13 GS until a few weeks ago when the dealer broke it while the car was in for service...I took it off while waiting on the replacement and like the look without it...so haven't put the new one on yet....it doesn't effect the cooling at all....and as far as aero...I had it on Atlanta Motor Speedway a couple weeks ago....and did not notice any problems...course I seldom go over 140 and then that's only for a few seconds....
when they mounted the ZR1 splitter they used the holes/clips that held the stock one on...but also drilled some random holes thru the splitter into the facia....
Old Oct 27, 2014 | 11:57 AM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Keep in mind there are slight indentations on the splitter where the clip fits so the splitter will fit flush. Either a little Dremel work or just use sheet metal screws...they work wonders.
Good luck.
Old Oct 27, 2014 | 12:23 PM
flyeri's Avatar
flyeri
Center fastener was broken on the wife's GS when we bought it. The bumper cover was broken where the threaded clip attaches. I removed the splitter and then loosened fasteners to access behind the front bumper cover at the center attachment point. I drilled a hole a 1" by 2" piece of aluminum and slid the factory clip on it. Slid this in behind bumper cover. This served as a backer for the broken cover and attachment point for the factory bolt.
There were also a couple places where the splitter drooped between factory attach points. I bought plastic automotive push-in fasteners to tighten up the droop. I think they came from Lowe's.
Old Oct 28, 2014 | 04:20 PM
jp_tt_awd's Avatar
jp_tt_awd
I just used fender washers about 2" in diameter and bolts with nuts in the spots where in factory clips had actually ripped through the bumper. I did that about 2 1/2 years ago and never had my splitter come loose again.
-jp
Old Oct 29, 2014 | 02:04 PM
Bazinga's Avatar
Bazinga
I want to thank everyone for the input!!!
Old Oct 29, 2014 | 03:35 PM
kennya35's Avatar
kennya35
When I bought mine, the splitter was missing. When I got home with the car I looked underneath and they must have dragged pretty good because the middle fastener was gone and a big hole was left in the fascia where it was supposed to attach (hope that made sense). Anyway, I finally bought a new splitter and when I went to install it, I used heavy duty two sided automotive tape and placed it on the entire splitter, and then fastened the splitter in place. You cannot see the tape, nor does the middle of the fastener sag due to the missing fastener.
To GS Splitter Question
