I have a 2006 and the problem I am having is when I go to put in park then hit the stop button it goes to Acc. and the info. center reads put car in park if I play with the shifter back and forward then it will go to off. Is there some kind of Adj?
I've had the shifter apart a few years ago. I believe there is a switch that has to be made for it to see it in Park.
The rod going to the switch could be bent a bit, or mis-aligned.
You probably have to take the top part of the shifter apart to see what is going on.
A dealer will try to sell you a new shifter unit at a big $$
