Lowering?
Old Oct 31, 2014 | 01:14 PM
glide's Avatar
glide
St. Jude Donor '13,'19
Default Lowering?
Is there an easy way to lower the rear of the C6 like the C4 and C5 (2 bolts). I first tried a search but came up short.
New C6 owner, old Corvette owner
TIA
Glide
Old Oct 31, 2014 | 01:20 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
http://www.superchevy.com/how-to/vem...g/viewall.html
Old Oct 31, 2014 | 03:30 PM
Hells's Avatar
Hells
St. Jude Donor '08
https://www.corvetteforum.com/forums...post1577643442
Old Oct 31, 2014 | 05:19 PM
tealex's Avatar
tealex
I have to raise mine up slightly on one side in the front to make the car level. Measured it at different points (frame to ground) and right side is low. Will I need an allignment after I'm done ???
Old Oct 31, 2014 | 05:34 PM
Entaille's Avatar
Entaille
most likely not - but tires are expensive and it doesn't hurt to check.
most alignment places will check alignment for free - just charge if they have to align it. some have a small 20$ fee to check etc.
Old Oct 31, 2014 | 06:40 PM
quadblackC6's Avatar
quadblackC6
How much does it lower? If you turn the lowering bolts all the way? Front n rear. Thanks.
Old Oct 31, 2014 | 06:46 PM
Entaille's Avatar
Entaille
probably ~half inch to .75 inch in the front, and half inch in the rear or so.
there is a bushing on the bottom of the bolt that you can saw a rib or two off of for additional lowering.. I took two ribs off of each and mine is low.
Old Oct 31, 2014 | 07:21 PM
haljensen's Avatar
haljensen
The car is set from the factory for weight distribution, NOT for body panel height. If appearance is more important than having correct weight distribution then change the height.
Any change in the suspension calls for an alignment. Stock alignments are usually poor. Tires are expensive get a $125 alignment.
Old Nov 1, 2014 | 11:16 AM
glide's Avatar
glide
Thanks for the 411! Easy mod. I did my 99 FRC way back when and still have the original AS Pilot Sports w 40K. No alignment issues with half inch drop IMHO. Also I just do the rears to get the stance I like. Front seams low enough already.
Old Nov 1, 2014 | 11:51 AM
tealex's Avatar
tealex
I have had the car 2 years in Jan. and have 8500 on it and have does 2 alignments already. The factory set up had way to much camber in it, ok for tracking the car but not good for tire wear/highway driving. I did not know the car was set up for weight distribution. I will not change the height now, thanks.
Old Nov 1, 2014 | 01:22 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
For those who do want to change things, each turn of the bolts will raise/lower the fender lip about 1/8" after things settle out over the next few hundred miles. Initially, the change may seem much more than that but it changes with miles.
For aero reasons, it's important to keep the same "rake" from front to rear. GM finally published measurements using the fender well lips for 2010, the rear lips should be 1.3" higher in the back for narrow body cars, .9" higher for wide bodies.
To Lowering?
