I've been on the C2 and C5 forums, first time here on C6
I've had a 2004 (C5) convertible since new, now thinking about selling and getting a used C6. Finances keep me at the older end of the scale...
Currently looking at a 2005 and a 2006 -- both convertibles -- and each with about 50K miles. Not a big step up in years from a 2004, I realize, but ride quality, color choices, and other options keep me interested.
Are there known issues I should know about in these early C6's? I'm trying to keep cash outlay to a minimum, but sometimes there are things that "everybody knows" that say "spend a little more and get a couple years newer".
You are going to get answers all over the board but...
I sold my 2005, 1SB, 6spd, vert with 45,000 trouble free miles. Yes, I had a couple dead batteries because I forgot to leave it in reverse. I never had DBS (dead battery syndrome) nor did I ever have an issue with the steering column lock. I didn't have the auto so there was no concern over potential shifter issues.
My recommendation:
Do your due diligence on cars in your price range. Find a local vette mechanic and let them go through the car first. When you find the one that trips your trigger...buy it!
My recommendation:
Thanks. I just found a link to a thread of FAQs including a section on "known issues". Guess I'll spend some time there
there is major disagreement on this, but the '05 was a great year car except that it did have a few issues which were not present in the '06 model. as with your C5, things change every year, every generation, and many times even during a model year. for that reason, you won't go wrong with either year's car, but if you can get an '06 for around the same price as an '05, do it.
I agree with AORoads and if you look around you can find very low mileage cars. I bought my 06 Z51, 3LT about four months ago with only 12,500 on the clock.
Because of the nature of the C6 (highly computerized & $$) owners generally had their cars serviced, under warranty, at a Chevy store.
As the MYs aged many people went independent for their service needs; but, until they did go indy whatever was done to the car was documented so whatever C6 you find will have documentation w/ GM.
When you find a C6 you think you want & before you bid, get the VIN.
Swing by a GM dealership, ask they run a GMVIS for you, IIRC this is done at no charge. A good C6 will have a good maintenance history proving it as opposed to a car with never resolved nagging issue(s).
FWIW rule of thumb purchasing a pre-owned C6: newer the better.
Not saying one cannot find an older MY that isn't solid, just there were '05 issue(s) addressed for '06.
I have an 'o7 vert A6 with 53kish miles. Bought it a few of months ago. So far I have had the shift cable (repaired) and harmonic balance (ordered parts Monday). These seem to be hit or miss but too common failures.
G/L
Makes sense...
Lots of times "first year" issues get resolved by following year. This is info I was looking for and appreciate. Thanks to all who've responded.
