TPMS Question
Old Nov 18, 2014 | 09:13 PM
terradriller's Avatar
terradriller
Default TPMS Question
I'm returning home from a trip to Florida and my right rear tpms is telling me I only have 22 psi in the tire. I check it and it shows 30 psi so I know I am good on air.
I have 300 miles to do tomorrow when I get home is there a battery to change or do i need a new tpms
427.
Old Nov 18, 2014 | 09:19 PM
R3L4X's Avatar
R3L4X
The battery can't be replaced, the tpms has to be replaced - if that's the problem.
Try adding a couple psi to the tire in question to see if the warning goes away first.
Old Nov 18, 2014 | 09:25 PM
87SAM's Avatar
87SAM
Did you check pressure in all tires? The TPMS may be pointing you to an incorrect location
Old Nov 18, 2014 | 09:26 PM
owc6's Avatar
owc6
That happened to me, and it drove me nuts till I figured it out.
Old Nov 18, 2014 | 09:59 PM
terradriller
I added a couple of pounds of air with no change. Good point that it may be a different position. Ill check all of the in the morning..thanks
So is this a dealer item?
427.
Old Nov 18, 2014 | 10:01 PM
jrose7004's Avatar
jrose7004
Time for a new one.
Old Nov 18, 2014 | 10:06 PM
TTZ06VETTE's Avatar
TTZ06VETTE
427.
No check Fleabay and Amazon.
Old Nov 18, 2014 | 10:15 PM
cclive's Avatar
cclive
Don't do 300 miles with a tire at 22 psi...you could ruin it or even have a blowout. Forget the TPMS and check all four tires with a handheld gauge. It is likely that one of your tires is at 22 psi. If the sensors have been programmed wrong, they can be re-programmed and all is good. This is more likely than one having gone bad so soon.
Old Nov 18, 2014 | 10:23 PM
terradriller
Checked all of them before leaving and all good. I've been having issues with this one position. It has been setting @26 psi cold even though it had 30 psi in it. The other wheels would show 30 and warm up to 33 the right rear just showed 26 now 23 since its cold. Again I will check a tires before I leave
427.
Old Nov 18, 2014 | 10:24 PM
87SAM's Avatar
87SAM
that's what I'm talking about, especially since it appears the OP has a 2013.
Old Nov 18, 2014 | 10:33 PM
terradriller
This is on my 2006. My 2013 - 427 is sitting in a nice warm garage
427.
Old Nov 18, 2014 | 10:42 PM
87SAM's Avatar
87SAM
427.
Well now you tell us
Old Nov 18, 2014 | 10:48 PM
Patman's Avatar
Patman
I've got one of my sensors that is definitely dying, it often gives me a zero pressure reading for a while before it finally kicks in and reads properly, and other times it'll read 3 or 4 pounds less than the rest even though a check with a proper tire pressure gauge shows otherwise. I just can't trust that sensor anymore and I plan on replacing it after the winter storage time is done.
Old Nov 18, 2014 | 10:49 PM
terradriller
9 years old I'll replace all of them...
427.
Old Nov 18, 2014 | 10:51 PM
Sudstrain's Avatar
Sudstrain
Last night on way back from Los Angeles to Las Vegas I have exactly the same incident.Right rear tpms is telling me 0 PSI.I did try to troubleshoot
and no success.Decided to replace with brand new.Good luck on yours.
Old Nov 19, 2014 | 11:12 AM
cclive's Avatar
cclive
427.
Absolutely...and don't let anyone tell you that the tires must be demounted and rebalanced to do it. The bead can be broken and then a reach in to replace the sensor...tire never leaves the rim.
Old Nov 19, 2014 | 10:39 PM
terradriller
So are there any after market sensors that are good or should I stick with OEM? Usually I like to stay with OEM
427.
To TPMS Question
Old Nov 19, 2014 | 11:31 PM
Sudstrain's Avatar
Sudstrain
I didn't have to replace ,dealership reset with hand held tool look like a tv remote control and it,s working fine.Maybe you should consult with chevy dealer and see what happens.
Old Nov 19, 2014 | 11:39 PM
Sudstrain's Avatar
Sudstrain
427.
By the way i do have 4 OEM TPMS from 2009 corvette wheels i purchase from guy in california if you interested let me know.
Old Nov 19, 2014 | 11:48 PM
owc6's Avatar
owc6
Resetting solves the problem? First I've heard of this. My guess (purely from having a few go bad over the years) is that, at best, it was temporary, and what is really going on is that it's starting to go bad, but decided to behave for the moment.
Sometimes they go bad in a flash and never come back, sometimes they take a couple years to go bad and stay bad. I've had them go both ways. I even had one give me a message, clear itself, and then, in the next 60,000 miles (that I owned the car) stay just fine (I think it was Onstar ping-related).
