I need to get a new one. I see there are many threads, some very old, on this already that jump all around on the issue and I don't want to wade through all of them. What is a good replacement and why? I'm stuck on Powerbond vs ATI. Are these the best or are there others just as good? I think I saw SLP and BBK. Anyway, mines a 2005 with 65k on it.
There are many good units. Anything that isn't OEM should do just fine. Before I sold my '07 I was looking at a beautiful unit from Summit. Beware under drive, by the way. Lots of residual problems can occur. As far as the ATI? Overpriced, a.k.a. voluntary Corvette tax. You can find a fine unit from $160-$275 and it will perform just as well as the ATI.
the ATI unit is only a few dollars more than the G.M. unit and G.M. uses the ATI unit on any engine it dosent want to chance hb failure on
The ATI is a really nice piece; we use it or Innovators West (for the bling) in most of our builds. Though the price may be a little higher, you get what you pay for in this instance in my opinion.
We underdrive most naturally aspirated Vettes we build, and usually don't have a problem, but we usually don't go over 12% underdriven. 25% under is way too far, and problems often occur at this level.
Though I don't have documentation to prove it, I'm pretty sure the SLP and PowerBond balancers are the same thing.
Feel free to call, email, or PM us anytime with questions!
- Jeremy
- Jeremy
Not to be a killjoy, but if you participate in NCCC speed events like autocross, they require you to run the stock HB. Bummer.
Since there is no performance advantage to the aftermarket HBs, I don't thinks it's really cheating, but rule book geeks would disagree.
Sorry.
Perhaps a careful repaint job before installation...???
I don't do any of that.
I've heard that I'm taking a big risk going with another OEM replacement balancer. I'm going to go ahead with the ATI. After I get this fixed I'll install the headers and the Vararam I ordered awhile back and get it all tuned.
Looking on different websites, I'm wondering if I need ATI 917246 or 917266? One is steel and the other appears to be a mix. Does anyone know if I will need different belts for this too, or will the stock ones fit?
So I ordered the ATI and it appears that it doesn't come with a crank bolt. Would an OEM crank bolt work with the ATI as a replacement for the old one? If not, any recommendations?
I may get the seal replaced at the same time. I'll see what the mechanic says.
I appreciate everybody's input on this so far. I really had no idea how much there was to do with replacing one.
I've been around a lot of motor builds....modifying and such....and have never seen any "residual" problems that could be called regular from an under-drive system. The slight difference in pulley speed shouldn't effect any accessory in a negative way....unless of course that particular accessory is faulty to begin with.
