Which one?
Old Dec 5, 2014 | 03:00 PM
Harry.s's Avatar
Harry.s
Default Which one?
Hey guys
In a small dilemma here..i'm looking to buy my first corvette in the coming weeks and narrowed it down to 2 i'm interested in.
They are both somewhat high miles but they fit the budget and maintenance records are there
Car 1: 2008 corvette single owner 120000 miles with all paperwork. Everything checks out however the only thing that worries me is the car has the original clutch still. The car was a daily driver driven to work every day
options:
3lt
two tone interior
Car 2: 2006 corvette 71000 miles second owner with a lot of maintenance records available as well. This car has a clutch replaced by the dealer new tires
options:
3lt
z51
The price difference between these is about $1500-2000 with the 2006 being a little more.
Which one would you guys get?
If the 2008 what would be a fair price on it?
Thanks a lot!
edit: the car will be primarily a daily driver
Old Dec 5, 2014 | 03:13 PM
RICH 28's Avatar
RICH 28
Car 2.
Old Dec 5, 2014 | 03:25 PM
not08crmanymore's Avatar
not08crmanymore
2008= more power 430 (436 w/npp) v.400hp in the 06,newer tranny and motor,enhanced steering,npp exhaust.i'd get the 08 if the miles don't bother you.it's more car for the money.bEAT THE GUY UP FOR 1500-2 GRAND ON PRICE TO COVER any clutch related issues you may encounter.
Old Dec 5, 2014 | 03:28 PM
jrose7004's Avatar
jrose7004
I would always go for the lower miles.
Old Dec 5, 2014 | 03:36 PM
irok's Avatar
irok
Originally Posted by Harry.s
Hey guys
options:
3lt
two tone interior
options:
3lt
z51
Thanks a lot!
in comparable shape I would go for the 06 with 50,000 fewer miles.there is very little difference in power between the two
Old Dec 5, 2014 | 03:46 PM
Jtaugner's Avatar
Jtaugner
I would say the 08' if you're not scared to work on your own car, possibly work the price down more.
Old Dec 5, 2014 | 04:06 PM
J Mills's Avatar
J Mills
The 06.. It will keep it's value as you put miles on it, and would be easier to resell than what will become an extremely high mileage Vette. In reality you will never notice the 30hp difference in these cars. Even with R888s I can't floor my car on the street in first. I would not look at that as the deciding factor.
Over time things like suspension bushings, clutch and anything mechanical begin to wear out. after 100K+ miles you are getting much closer to the end of life of many components and should expect to pay more for failures.
Ask yourself if a slightly newer car with a negligible power difference is worth the additional potential maintenance vs. the older lower mileage example. In the end you will love either, so it's a great decision to have to make!
Old Dec 5, 2014 | 04:08 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
If the '08 has had regular maintenance and any issue fixed over the years, 120K is not bad. The LSx engines if well maintained are good for 250K+. I will agree the HP difference is not that great.
Although the LS2 is rated at 400, it is in fact somewhere between 406 and 410 in reality. There is a long post on this issue here on the forum. Some say GM released it at 400 so as not to upset the C5 Z05 owners with 405 hp.
I do agree with the post that stated go with the '06 based on the difference in mileage, plus it was equipped with the Z51 option, which I have on my '07 and love it.
Old Dec 5, 2014 | 04:09 PM
Vette_DD's Avatar
Vette_DD
I'd go for the 06 because of the mileage.
The 015 model year cars are out, so the 08 is 7 years old, while the 06 is 9 years old.
The 08 was driven approximately 17,000 miles a year, while the 06 was only driven approximately 8,000 miles a year.
Old Dec 5, 2014 | 04:22 PM
wayback's Avatar
wayback
Both in the same condition?
If so don't let the mileage scare you off. Get someone to check it out or bargain to have dealer replace the clutch.
Old Dec 5, 2014 | 04:40 PM
piper_chuck's Avatar
piper_chuck
I would lean toward the car with lower miles. However, one question does come to mind about it, why was the clutch replacement needed? The car doesn't have a huge amount of miles. Was there something unusual that one of the past owners did to lead to clutch failure, or was it just a bad one?
Old Dec 5, 2014 | 04:52 PM
dcarter0001's Avatar
dcarter0001
Neither. They are both high millage cars. There are a lot of Vettes with low millage out there since most are not used as daily drivers. A good low millage may cost a little more but in the long run they will be a lot less trouble.
Old Dec 5, 2014 | 05:20 PM
not08crmanymore
It's not just power that was changed.It was a better shifting,newer transmission,better steering feel due to updates there as well. They're both high mileage vettes so resale should not even enter into the equation since they will both be pretty much shot in that department in very short order. For 1500 bucks,the sell of the 08 can lower the price that much and then they are the same price....so mileage aside, the 08 is more car.
Old Dec 5, 2014 | 07:40 PM
Harry.s's Avatar
Harry.s
Thanks for the advice guys.
If I can get the 2008 guy to come down i'll be all over the car if not i'm leaning towards the ls2 . I didn't consider some other maintenance items such as suspension and bushings with that many miles.
I'm comfortable doing all my own work but I prefer to drive the car more for a while before I gotta start replacing bushings and other small things.
Only major difference for me is the ls3, i've driven both a t56 transmission car and a t6060 and don't see much of a difference either
Thanks!
Old Dec 5, 2014 | 07:42 PM
Stickshiftsteve's Avatar
Stickshiftsteve
As a DD - I'd go with the lower miles & clutch replaced.
Less chance of mechanical issues.
Old Dec 5, 2014 | 10:59 PM
Rick369's Avatar
Rick369
Definitely go with the 06. 50,000 less miles is a lot of miles that you can put on the car. You will probably never feel the difference between 400 hp and 430 hp. Also the 06 has the Z51 handling and suspension package, which will most likely give you a better handling car than the 08 with the standard suspension. Both cars have the 3LT package. I assume you like the interior/exterior colors of both cars.
Old Dec 5, 2014 | 11:04 PM
42Chevy's Avatar
42Chevy
It's 5 o'clock Somewhere
St Jude Donor '13-'14-'15
Both have too many miles. There are so many low mileage cars on the market. This is one time I would suggest you keep looking unless the price is ultra low and thats all you have to spend.
To Which one?
Old Dec 5, 2014 | 11:28 PM
v26278's Avatar
v26278
120k on the original clutch tells me the owner knew how to drive better than, or abused the car less than, someone who toasted the clutch before 70k. I'd be leaning to the '08 even with miles, provided the service records look good.
Old Dec 5, 2014 | 11:30 PM
Kvothe's Avatar
Kvothe
For your purpose it sounds like the lower mileage vehicle would better suit your needs. 50K is a ton of miles difference for a DD. If this was a different car I'd bet the majority would say get the lower mileage vehicle.
Old Dec 5, 2014 | 11:31 PM
Rick369's Avatar
Rick369
The OP said he had a budget and these two cars fit in his budget. I disagree that the 06 has too many miles. 8,000 miles per year is low miles. I would rather buy a car that was driven regularly and was well maintained at a reasonable cost than a garage queen with low miles at a much higher cost.
