Alignment ??
Old Dec 10, 2014 | 03:32 PM
Mark H's Avatar
Mark H
Default Alignment ??
Going to the local dealer in the morning for alignment after putting on a set of Firestones today. My question is should I take the PFADT specs or let them use factory specs. Just looking for good even tire wear. The front tires I replaced were worn on the inside, although the right more than the left.
These are the specs I found searching the forum.
https://www.dropbox.com/s/9q85na7tvv...ions.docx?dl=0
Old Dec 10, 2014 | 03:36 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
You don't tell us if you are driving a base, Grand Sport or ZO6. I cannot speak for the base model, but an alignment to Pfadt street specs greatly improved tire wear on our Grand Sport.
Old Dec 10, 2014 | 03:39 PM
rmiller86's Avatar
rmiller86
I would take the PFADT specs with you, factory specs are for the track. I would however call the dealer to ensure that they will set it up that way, if not, find a good shop that will. If they will show you, see how the car is setting with the factory specs and then compare the numbers at the end. Try and get a print out of before and after if you can.
Old Dec 10, 2014 | 04:07 PM
Not So Fast's Avatar
Not So Fast
This shows the print out of my recently done alignment by the only shop in this Podunk town, Chevy dealer.
For what its worth
https://www.corvetteforum.com/forums...ent-specs.html
NSF
Old Dec 10, 2014 | 04:34 PM
Dano523's Avatar
Dano523
Use this sheet instead (no wiggle room),
http://www.pfadtracing.com/docs/camb...t-settings.pdf
If the insides are worn out, and the middle and outer edges not, then go with the pure street alignment instead of even the factory alignment specs.
The factory alignment is semi aggressive for track/street, and you are not pushing the car hard enough to get a evenly wear the tires with even the factory alignment.
Also add, there is a steering wheel sensor in the car (accessed/read through the OBDII port), so when they aligning, the should be zeroing out on the wheel sensor at zero too (not just looking at the steering wheel and guessing if it centered of not).
Lastly with the amount of adjustments on the vet for all 4 wheels, it does take some time to get it all right. 30 to 45 mins is the norm to have a zero steering wheel/alignments print read out all correct. If they can not get it right, or tell you that there is not way to get the alignement to the specs per the above link, find another shop.
Not only is there the standard adjustments on the bottom end points, but spacer shim in the upper A arms if you run out of adjustments on the standard lower adjustment points to get the car to align correctly.
Old Dec 10, 2014 | 04:48 PM
Mark H's Avatar
Mark H
Thanks for the info guys!!
Old Dec 10, 2014 | 04:50 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I think the issue is the tolerances. You can be in “spec” but be far to one side or the other of nominal. I would take the PHAT recommendation but try to have your technician “nail it”.
Old Dec 10, 2014 | 04:59 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
GM allows for a wide variation of settings to meet their acceptable spec.
Some Dealers will use this to just get it close and then say it meets specs.
You need to have the Tech take the time to get the numbers spot on and using the PFADT street/track settings will give you the good handling/tire wear you're after.
Old Dec 13, 2014 | 01:11 AM
MTsVette's Avatar
MTsVette
From: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
I had my local Chevy dealership set my camber on all 4's to 0 camber. No real noticeable handling difference. Now all 4 tires will wear evenly.
MT
To Alignment ??
By Michael S. Palmer | 2026-06-03 09:39:05
