Wipers Humming
Old Jan 6, 2015 | 07:42 AM
edmerc's Avatar
edmerc
Cruising
Default Wipers Humming
I have a 2013 C6 and had my summer tires replaced with all season mud and snow tires (speed rated 186 plus and run flat no less). Ever since I swapped the tires the passenger side wiper hums loudly at 75 or over. The wiper looks fine but does not lay flat on the windshield at the far edge (sits up about an inch. They are good quality aftermarket wipers. Did the dealership screw something up? Or is it I'm just getting vibration from the tread in the new tires?
Ed
Old Jan 6, 2015 | 10:48 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
A fairly common problem on the C6 is that the plastic trim piece (cowl?) at the bottom of the windshield gets a little loose and starts to hum at highway speeds. There is some kind of GM bulletin that explains the problem and how to fix it.
Ours started doing the hummmmmm after about 5 yrs/70k miles. At the next oil change, I had the dealer do the approved fix, they charged me almost nothing and it's been fine.
Or you can do a Search here for "cowl hum" or something similar, there are several ways to skin that cat.
Unless it's actually the wiper...
Old Jan 6, 2015 | 12:58 PM
PatriotZ's Avatar
PatriotZ
Veteran: Marine Corps
From: "No matter where you go... there you are"...."You cannot drive a dollar bill". ...and remember... "D
Gearhead is correct here.....search the Forum for the fix and cure....many of us have used silicon to solve the problem
Old Jan 6, 2015 | 07:22 PM
1RB's Avatar
1RB
Ed
Suggest you have your dealer check #PI0766: Buzz Noise Heard Near Base of Windshield at Highway Speeds - (Jul 17, 2012) for a solution to a cowl molding issue. That may be what you're experiencing.
Old Jan 6, 2015 | 07:56 PM
Not So Fast's Avatar
Not So Fast
You drive it in the rain ??? Sacrilegious LOL
NSF
To Wipers Humming
