All C6 friction material until 2012 was semi metallic. PBR was the supplier.
In 2012 GM used the first ceramic friction for the base C6. It was the Performance friction made by Akebono. The GS, Z06 and ZR1 still used a semi metallic friction.
Thanks, if the material was semi-metallic across the board. What was the difference between Z51 and Base pad material? Would the JL9 standard pads be less aggressive and dust less than the Z51(J55) pads?
Not the (2012) GS.....mine (M6) and a friends (A6) are (were) the super dusty, fast wearing, rotor eating semi-metallic pads. I changed mine out to the ceramic pads at 2K, and my friends out at 21K.
Ditto, and huge fan of the J55 heavy duty brake pads (evil brake dust and all) since they have more bite than the standard JL9 pads).
As I stated before, all GS, Z06, ZR1 came with semi metallic pads. As for your A6 friend it would depend on when his model was made as to what came OE. Also the Performance ceramic pad that was used was a much more aggressive ceramic pad then that you buy at a big box store.
