Doing Oil Change Need Help!!!
Old Feb 10, 2015 | 03:40 AM
GrandSportMike's Avatar
GrandSportMike
Default Doing Oil Change Need Help!!!
So I Have A 2013 Corvette Grand Sport 6.2 LS3 What Kind Of Oil Filter And What Kind Of Oil Do I Use The Car Has 17K Miles Please Help I Been Looking And Can't Find Anything
Old Feb 10, 2015 | 04:12 AM
C6ToGo's Avatar
C6ToGo
I don't think anybody makes an oil filter for that model any more. Good luck in your search.
Old Feb 10, 2015 | 04:42 AM
GrandSportMike
Are You Serious
Old Feb 10, 2015 | 05:11 AM
Don-Vette's Avatar
Don-Vette
Mobil 1, 5-30 oil
Filter:
Mobil 1: -M1-113
Purolator pure one: PL-12222
AC Delco: PF-48
K&N: HP-1017
Cabin filter: Purolator C25623
btw,read the owners manual and follow the maintenance schedules.
Old Feb 10, 2015 | 06:24 AM
Seadawg's Avatar
Seadawg
Originally Posted by GrandSportMike
Are You Serious
He's messing with you '
But seriously, any auto place (even Wal-Mart) has the books and displays that shows what oils and filters you need.
And, like said above, you really need to read your owner's manual, not just for this, but to get familiar to all of the features of your car.
You also don't say if it is a dry sump or wet sump. I'm not gonna tell you how to tell, you have to read your owner's manual.
On a serious note, you do need to know, because it takes a different filter, and a LOT more oil for the engine on a dry sump grand sport LS3
Old Feb 10, 2015 | 07:42 AM
R&L's C6's Avatar
R&L's C6
Here you go, everything you need to know.........
http://www.chevrolet.com/content/dam...13corvette.pdf
Old Feb 10, 2015 | 07:59 AM
Hameister's Avatar
Hameister
2015 C6 of the Year Finalist
This cannot be a serious post! It's a joke right?
This information is in your owners manual, you could Google it, you could look at the filter chart in any auto parts store, Wal-Mart, it's available every where.
You say you've been researching and cannot find this information?
If that's actually true, then I think you'd be better served by having a professional change your oil. Don't trust yourself.
Old Feb 10, 2015 | 08:06 AM
Cooter Tech's Avatar
Cooter Tech
Jiffy Lube will do an excellent job on it. They will even check the tire pressure for a minimal charge.
Old Feb 10, 2015 | 09:46 AM
dmoneychris's Avatar
dmoneychris
Amsoil has you covered. I use the 0w-30 Signature Series oil in my 2013 Grand Sport w/the dry sump LS3. I recommend it.
Engine Oil- (https://www.amsoil.com/shop/by-produ...?code=AZOQT-EA )
Oil Filter- ( http://www.amsoil.com/shop/by-produc...ode=EA15K50-EA )
Brake & Clutch fluid- ( https://www.amsoil.com/shop/by-produ...?code=BF4SN-EA )
Old Feb 10, 2015 | 09:49 AM
juanvaldez's Avatar
juanvaldez
Is it a manual coupe?
Old Feb 10, 2015 | 09:53 AM
Cooter Tech
I have heard a lot of good reports on Amsoil (SP?) oils. Anyone else using this oil or have any comments?
Old Feb 10, 2015 | 11:05 AM
Homer3D's Avatar
Homer3D
I don't know where the OP was looking but Mobil 1 5w-30 is right on the oil filler cap. If you weren't able to find that when you were looking where the oil should go, maybe you shouldn't be changing your own oil.
Old Feb 10, 2015 | 11:32 AM
EVRose's Avatar
EVRose
X2. This is not a job he should be doing if he can't figure out the 2 most basic maintenance requirements.
Old Feb 10, 2015 | 02:00 PM
Hameister's Avatar
Hameister
Yeah, I think this thread was started as a joke.
Old Feb 10, 2015 | 02:39 PM
GrandSportMike
Ok Everyone It's No A Joke I Have Asked Auto Zone They Told Me I need 10 and a half courts of 15-30 Oil And The Oil Filter Was like $120 it didn't make any sence to me I'm not doing it myself I like to buy the oil and filter and bring it to a shop to do it so I know there putting in the right stuff and not some cheepy **** my car didn't come with the owners manual I went on Google but again I don't know about this dry sump thing I thought the forum was for people asking help and talk about it sorry to everyone
Old Feb 10, 2015 | 02:42 PM
Don-Vette's Avatar
Don-Vette
Why don't you download the owners manual in pdf and keep it on you desktop? I also have it downloaded on my phone. No rocket science here.
Old Feb 10, 2015 | 03:53 PM
Hameister's Avatar
Hameister
In a previous post R&L'sC6 gave you a link for the owner's manual.
It contains everything you'll need to know.
If your transmission is an automatic, it's about 5 qts. I'm not certain because I don't have an automatic.
If you own a manual 6 speed transmission, you have a dry sump oil system that takes 10.5 qts., and the oil filter is different as well.
In either one, GM recommends Mobil 1 oil. That manual is your friend.
To Doing Oil Change Need Help!!!
Seadawg's Avatar
Seadawg
Hey, our bark is much worse than our bite Now we are getting somewhere, you have a dry sump.
I get my oil at Wal-Mart, it is 5-30 Mobil 1, and it is about $25 for a 5 quart container. So, it's about $60 worth of oil. The dry sump uses a higher pressure rated filter, and I order mine thru Amazon, and get the Mobil M-113 filter. There are 2 drain plugs for the dry sump, and you really do need the PDF manual, read about how to change you oil, because there is a process on how to even check the oil. Go to this site, and download it. http://www.chevrolet.com/content/dam...13corvette.pdf
We will help you, just keep a thick skin
Old Feb 10, 2015 | 04:00 PM
Hameister's Avatar
Hameister
Originally Posted by Don-Vette
Mobil 1, 5-30 oil
Filter:
Mobil 1: -M1-113
AC Delco: PF-48
K&N: HP-1017
Don, the PF-48 filter is only for the automatic.
The dry sump uses a UPF-48R filter.
Old Feb 10, 2015 | 04:09 PM
Hameister's Avatar
Hameister
You got that right. Still can't be certain he has a dry sump system though.
He said they guy in Auto Zone told him he needed 10.5 qts.
Maybe the guy at Auto Zone checked it out and he's correct, or maybe he assumed because it was a GS, it was dry sump?
I've seen others say the same thing when the car was in fact an automatic.
I've learned not to assume anything.
What say OP, you got a stick, or an auto?
