Question
Mar 24, 2015 | 04:35 PM
Question
Question? 2012 corvette . Mobil 1 is correct? Which one do i use and how many quarts? Thank you.
Mar 24, 2015 | 04:56 PM
Yes on the mobil 1 oil,
What motor, and is it dry or wet sump?
Insufficient information about your 2012 C6. What model? Different engines use a different amount of oil. Coupe, Vert, Z06, ZR1, which one?
Mar 24, 2015 | 04:58 PM
2015 C6 of the Year Finalist
Quote:
Originally Posted by
ralfano
You need to consult your owner's manual. Capacity depends on your Corvette model which you do not indicate, Base? Grand Sport? Automatic, Manual, What?
Consult your manual's maintenance schedule for the weight as well.
EDIT: Hee, looks like we were all typing, posting, at the same time.
Mar 24, 2015 | 05:23 PM
hameister
you need to consult your owner's manual. Capacity depends on your corvette model which you do not indicate, base? Grand sport? Automatic, manual, what?
edit: hee, looks like we were all typing, posting, at the same time.
2012 grand sport coupe auto thank you
Mar 24, 2015 | 05:24 PM
vette_dd
insufficient information about your 2012 c6. What model? Different engines use a different amount of oil. Coupe, vert, z06, zr1, which one?
2012 grand sport coupe. Auto
Mar 24, 2015 | 05:28 PM
2021 C6 of the Year Finalist - Modified
5.5 Qt. of Mobil 1 (5W-30)
The filter is an AC Delco PF48
(both avail at Walmart)
Mar 24, 2015 | 05:33 PM
Owners manual. Read it.
It tells about your car. Things you need to know.
Mar 24, 2015 | 05:38 PM
turbo6ta
5.5 qt. Of the standard mobil 1 (5w-30)
the filter is an ac delco pf48
(both avail at walmart)
thank you
Mar 24, 2015 | 05:44 PM
BTW ... Some owner's manuals for the C6 Corvette may say to use 6 Qt of oil ... That will overfill it.
Use 5 1/2 Qt with an oil and filter change.
Mar 24, 2015 | 05:50 PM
BTW ... Your not stuck by using only Mobil 1 oil ... Any good 5W-30 that's 100% synthetic would be fine, but the 2012 did come from the factory filled with Mobil 1
Up to you ... look for the approved 'dexos 2' logo on the bottle (if your concerned with that)
Mar 24, 2015 | 05:53 PM
An extra half quart wont do any harm at all. I've been using a full 6 for nearly 5 years no problem.
Mar 24, 2015 | 08:12 PM
LMB-Z
OP , you have your answers, however, I would also suggest that you spend some time with the owner's manual.
This time you got answers from folks who know what they're talking about.
Next time, you may not be so lucky. The owner's manual is always accurate!
Mar 24, 2015 | 08:24 PM
St. Jude Donor '11-'12-'13-'14
EVRose
