Emission Recall
Old Sep 17, 2015 | 09:53 AM
  #41
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Does this mean you will now suffer the same hot right leg as I do in my 4 cat 2012?
Old Sep 17, 2015 | 03:41 PM
  #42
Walt White Coupe's Avatar
Walt White Coupe
The recall is voluntary but California wants it done prior to registration.
This is a misunderstanding of the recall letter. GM is "voluntarily" conducting the recall and is not being made to do it by an order from the EPA.
For the individual owner, all recalls are voluntary.
Old Sep 17, 2015 | 07:48 PM
  #43
Boomer111's Avatar
Boomer111
Yes alright but the catch is that in California one will not be able to register the car without having the recall performed. Irrespective of the existing cats working or not.
Old Sep 17, 2015 | 08:10 PM
  #44
Walt White Coupe
They won't put you in jail for not getting a recall. It's voluntary. Now if you want to register your car, that's another matter. We should all be for cleaner air. My opinion.
Old Sep 17, 2015 | 09:44 PM
  #45
Mike's LS3's Avatar
Mike's LS3
No, they won't put you in jail for not complying with the recall. However, in CA if we don't comply, getting pulled over for expired registration will be a bit of a pain in the azz. So much for a voluntary recall.
Old Sep 18, 2015 | 02:23 AM
  #46
txbullets's Avatar
txbullets
Didn't want to start a new thread on same topic but I am curious what do the performance shops / vendors think of the recall? Is it truly an upgrade or downgrade for those with stock exhaust and cats.
I have read most of this thread and the "butt dyno" says its faster after the recall.
How about some numbers? Any shops that would run a before and after dyno?
Old Sep 18, 2015 | 10:34 AM
  #47
Mike's LS3's Avatar
Mike's LS3
Adding two additional catalytic converters (4 total) will add more back pressure which might feel like the car has a little more bottom end. This added back pressure loses a few HP in the midrange and top end. Most likely, not to be felt.
However, we do not know "If" or "Any" improved performance is due to partially clogged catalytic converters or a the reprogramed ECM. Without comparing the original to the new ECM files, one can only guess that GM leaned out A/F ratio a bit at WOT.
I would prefer GM just replace the original converters and not add two more smaller cats downstream.
To answer your question, it's only an upgrade if your catalytic converters are clogged.
Old Sep 18, 2015 | 11:43 AM
  #48
Walt White Coupe
Or if you are trying or intend to sell your car in the future. New cats over 7 to 9 year old cats would make your car more desirable.
Old Sep 18, 2015 | 07:18 PM
  #49
wzp's Avatar
wzp
I received the recall letter on Wednesday, 9-16-2015 on my 2008. Today (Friday) I called GM & went to local Chevy dealer where I've had service performed on my 2008 Vette, including changing leaking oil pan gasket while under warrenty. They do excellent work. GM rep that answered the phone could hardly speak or understand English. I was not happy. Went to local dealer. Left very happy and satisfied after speaking with service manager. I was told in short, after lengthy discussion with the service manager drive it and enjoy it. When and if it ever fails emissions because of the cat's, then have them replaced. A recall notice does not expire. I live in CT, where these emission standards apply, which I still do not understand, along with most of the East coast
Old Sep 18, 2015 | 07:37 PM
  #50
wzp's Avatar
wzp
I also asked about the cat's getting clogged. They are not like the old ones with the beads in them, they have a honeycomb web in them that do not clog or collapse. When they fail, they don't burn the gases going through and register a check engine light. I also asked about registration. I was told that your registration cannot be denied because of a recall. If the dealer was selling a car with a recall and they knew it then yes the registration could be denied but not with the current owner. You can still register your vehicle
Old Sep 18, 2015 | 10:02 PM
  #51
djbrun's Avatar
djbrun
FYI, honey comb style cats have been in use for a while and can burn up, which includes melting, breaking apart and pieces turning sideways. Then breaking off and working their way into your muffler.
DJ
Old Sep 18, 2015 | 10:20 PM
  #52
Boomer111's Avatar
Boomer111
Important message for California residents:
The California Air Resources Board (CARB) requires vehicle emission recalls be completed prior to Valifornia registration renewal. U corrected emission recalls will result in the inability to renew your California vehicle registration.
This is word for word from the letter I recieved from GM concerning the recall.
We out in in the Golden State have no choice.
Regarding clogged I admit my knowledge is outdated, as is a lot of other things.
Old Sep 19, 2015 | 11:08 AM
  #53
Mike's LS3's Avatar
Mike's LS3
DJ
... and if small enough through the muffler. That's one of the reasons when dyno tuning your car, "Never stand in front of the exhaust pipe!"
Old Sep 19, 2015 | 11:38 AM
  #54
Dif's Avatar
Dif
Lots more info from others like myself that had it done.
Long story short, I'm glad I had it done.
Mine runs Noticeably better.
https://www.corvetteforum.com/forums...rs-h-pipe.html
Note: the "Voluntary" part is by GM.
Doubt anyone will come and track people down for not doing it.
But, GM is Voluntarily offering this Recall on their own preemptively, it's not voluntary for the consumer.
Just sayin"
Old Sep 19, 2015 | 05:21 PM
  #55
djbrun's Avatar
djbrun
Just sayin"
Not voluntary in California as already mentioned.
DJ
Old Sep 19, 2015 | 06:05 PM
  #56
Black08Vette's Avatar
Black08Vette
Just got my recall. Curious about before and after dynos.
Old Sep 19, 2015 | 06:06 PM
  #57
Dif's Avatar
Dif
DJ
In California, it's a catch 22.
GM, is "voluntarily" offering this recall for free.
But it is not mandatory for GM to do this.
Yes in a sense it's not voluntary for someone in California because if they refuse to do it, they will have to "Pay" for the recall work out of pocket to get their vehicle to pass inspection when the time comes to get it inspected.
If you don't live in California then it's also voluntary for the consumer.
I'm in Mass and my 09 falls under the Cali emissions but, I passed Inspection when I went for a sticker.
That's when they told me about the emissions recall and I had it done a few weeks later
Now whether or not Mass or any other state with Cali standards is going to change how they do sticker/emissions in the future is anyone's guess
To Emission Recall
Old Sep 21, 2015 | 04:51 PM
  #58
Eric 1988's Avatar
Eric 1988
Default dont do this if you like the rumble of your dual mode exhaust
don't do this if you like the rumble of your dual mode exhaust
2009 z51 7,500mile with dual mode exhaust.
I had this done 2 months ago and the dealer has been trying to get me a solution ever since. Just came from there, they thought they may have found a solution but still no. My issue, the nice rumble at start up basically gone, the instantaneous nice rumble at the push of the throttle gone. You still get some rumble, but not nearly as quick or as nice as it was - I would not recommend this recall for anyone who loves the nice dual rumble of the exhaust option dual mode (also known as Option NPP or dual note or etc).
From what I see some people are happy with this, i.e they have a lot of miles and they got a new cat system for free, they don't mind the lost of the sweat rumble, the performance improved because of bad cats, etc, but if you love the dual mode sound you will probably be disappointed like me.
Some people claim more power some claim less. Without a dyno test before and after I don't know what you can really say. the black marks on the pavement look the same to me before and after. what is lost is that sweet sound!
Old Sep 21, 2015 | 05:27 PM
  #59
Dif's Avatar
Dif
IMO, long story short, you just need different louder Mufflers and you'll be good to go.
And you'll still be able to use NPP with the right setup.
Good Luck
Old Sep 21, 2015 | 08:52 PM
  #60
Boomer111's Avatar
Boomer111
I just have the Corsa Sports and I am sure they will be quieter losing the 3in pipe back to 2 1/2in.
One person who will be happy is the wife!
I am resigned now with California be so strict. Which is ok after 7 years I am not driving the car as much.
Sounds like sour grapes maybe but what one going to do? Just tired of fighting the emissions. It is just to costly changing all the time.
