However, one thing that the Corvette engineer mentioned is that the ECM would be programmed to lean air fuel at low rpm. The computer is programed to maintain 14.68 air fuel ratio at cruise or part throttle. Leaning out that value would probably do more harm to the catalytic converters and performance, especially with the ethanol in todays gas. From what you described with your car, I bet they leaned out open loop or wide open throttle values. This would increase performance, especially because the factory tune commands a rich 11.25 to 11.75 air fuel ratio. I would love to compare the new vs. original tune. When I get the recall done I will make a copy of the tune to compare. It will be interesting to see what GM actually did to the ECM.
The other reason that your car runs better just might be that your cats were starting to get clogged.
Enjoy your car!
Your knowledge is far superior to mine. I commend you on that. Maybe the new catalytic converters are purpose built/tuned for a lean or mixture? I have heard that the new c7 runs leaner maybe they are an offshoot of that research? That being said the overall performance of the car is amazing now. Please tell us what you think when you have it done, I am really anxious to hear. Thanks for your response.
Enjoy your car!
Thanks Mike. I'd love to see you results/analysis of the new tune after the recall is done. I live in Carlsbad, CA and had the recall done a couple of weeks ago. My SOTP is that it is a little quieter but with no change on performance or mileage.
If it ain't broke and passes state inspection. Dont fix it!! Disregard any notice. IMO
that's brillant! GM found that they had a problem with the cats and had tuned the car to those cats and now they want to correct the problem and fix the car free, keep driving around on plugged/restrictive cats. have fun, if you have a "custom tune" I would TELL them not to reflash, but I would definitly get free new cats and then see my tuner, to those who have stock they DID NOT SELL A DETUNED MODEL FOR CA. THEY ARE NOT GOING TO TAKE ANYTHING AWAY JUST THINK!!!! IT MIGHT GET BETTER!!!!! but watch out for the black drones that will follow you around now.
It's all or nothing on the 14523 recall. They won't let you cherry pick what portions of recall to complete, & once you have it done there's no going back. See my prior post on what the car runs like after the recall was done.
A little quieter, no noticeable loss of performance. Trip next week will be the acid test.
Bill
I just got back from Folsom Chevrolet in Folsom, CA, who sold me my 09 1LT almost three months ago. They performed the emissions recall work in a total of 2 1/2 hours as promised, including cool down time for the exhaust system. It's about 21 miles from my front door to the agency, so that's the extent of my experience thus far. I did get to drive it on 50+ mph express ways and on a very twisty country road on the way home. Aside from the slight smell of the new cats and exhaust pipes burning in, the car does seem to be a little more responsive at the low end. Otherwise, it's still the same pleasant driving experience it was before the cats and re-flash of the ECM. I'm happy with the agency and with the mods.
Do not do this if you like the sound of you dual mode exhaust NPP
Originally Posted by NotSureURnice
I got the notice and nobody could tell me what was going to happen if I did it. So I weaseled my way into General Motors corporate and spoke to one of the top Corvette engineers. He told me that the catalytic converters are better than the stock units in that they flow more freely. He also said they will never plug up. Which is why the old ones were recalled. So if you leave the old ones on you are actually D tuning the car because the old ones are plugging up. get the recall done. In terms of the reprogramming of the engine control module he said all it does is lean out the air/fuel mixture at low rpm. There will be no performance change whatsoever. However mileage will increase in the city cycle. Now that I have had the recall done I can tell you the car is actually better performing than prior to the recall especially at low rpm. I was very wary of having this work done because fooling with the emissions is problematic at best. But I am very glad I had it done for two reasons the first reason is because the car sounds better the second reason is because the car performs better and I am actually seeing increased mileage as promised. I encourage you all to make your own decision however take this post as an indicator that the recall when performed correctly actually improves the vehicle in many ways. I hope this post helps you.
There is another post where I have been responding also. I am looking for a solution to correct my car after this recall was done. It no longer has the nice rumble i bought the car for! Mine is 2009 7500miles z51 with dual mode exhaust. The great sound is gone. Dealer is doing nothing. Really mad. If your cats were getting plugged or your car has a lot of miles or you don't mind making it sound like a non dual mode exhaust car this is probably a good recall. Me a sunday driver in wisconsin - extremely disappointed. So mad looking at aftermarket but not happy to spend $2k on sytem i had before recall and doubt it will be the same. Any suggestions would be appreciated.
You can thank your state's government. 10 other states follow CARB (California Air Research Board) regulations (Connecticut, Maine, Maryland, Massachusetts, New Jersey, New Mexico, New York, Oregon, Rhode Island, and Vermont).
Only part of Maryland. There aren't any emissions check on the Eastern Shore.
So, this thread was started in May '15 (when you happened to join the site also) and you state "So I weaseled my way into General Motors corporate and spoke to one of the top Corvette engineers."
I mean no offense here although it likely comes across that way but...
What exactly did you do? You went to GM HQ and told the receptionist that you were there to speak to one of the top Corvette engineers? I commend you for contributing to the thread certainly, just curious for more details.
*** Received letter today 9-15-15 for my 2008 3LT Z51 with 44,460 miles with B&B Fusion exhaust in New Jersey.
Made earliest appointment with dealer for 9-29-15 @ 7:30am. Will let you know when it is done.
Recall number - N140523
GM Program #:
N140523
Date Issued:
Mar 30, 2015
Program Title:
EMISSION COMPLIANCE
Program Status: INCOMPLETE
Reason: Recall Number N140523
GM Program #:
N140523
Date Issued:
Mar 30, 2015
Program Title:
EMISSION COMPLIANCE
Please let us know if they indeed add two more catalytic converters like the 09 recall or (cross my fingers) 08's just replace existing ones.
Confirmed that the 2008 gets a new mid pipe because it does have the smaller cats added, making 4 now just like the 2009 recall. Now all the LS3's have 4 cats in the C6's.
I am in Mass and got the recall, my understanding is that Mass adheres to the California rules.
Does anyone know if a car will still pass inspection if this recall is not completed? I wonder if emission related recalls require manufacturers to submit a list of VINs to the state inspection agency, and if they update the list when a car has the recall done.
I have to assume that states who use CARB will fail your inspection for emission recalls that are not completed...unfortunately..
The recall is voluntary but California wants it done prior to registration.
Access to the cars computer is needed for refresh as well as gaining vital information for the certificate of compliance that is needed for renewing registration. Everything nowadays in tracked via computer.
The car may or may not pass your States testing depending on if the sniffer is still used and if the cats are plugged. The cats still might perform well but California does not want to take any chances. We no longer have the tail pipe test on newer models. Just the OBD11 test for system readiness and the visual inspection.
Good point, yes in MA it's just the ODBII so I have to think that as long as it's not throwing a code...the car should pass inspection.
As far as Registration renewal goes...the recall letter mentions CA specifically...
I'll dig a little more, but if I can confirm that the car will pass inspection and renew registration...I'm not going to allow the exhaust system on a low mileage car to be mucked with
