Sagging seat
Old May 25, 2015 | 10:57 AM
slburgie's Avatar
slburgie
Default Sagging seat
Can heating up the bolster (side of drivers seat) with a steamer shrink the material tight again or will it only stain the material. I believe the only leather part is he center areas. Anybody tried it?
Old May 25, 2015 | 11:03 AM
wayback's Avatar
wayback
There are seat kits to fix this problem. One vendor here sells a heavy duty foam replacement for $69 and another sells a kit with jute and extra foam to add to your seat. Do a search, lots of info.
Old May 25, 2015 | 11:06 AM
slburgie's Avatar
slburgie
I've replaced the foam with heavy duty foam and that's when the wrinkles appeared.
Old May 25, 2015 | 11:15 AM
gr86ss's Avatar
gr86ss
Using a blow dryer or heat gun is a better solution for getting the leather to stretch/shrink.
Old May 25, 2015 | 11:23 AM
dcarter0001's Avatar
dcarter0001
Let us know how that works out.
Old May 25, 2015 | 12:19 PM
HOXXOH's Avatar
HOXXOH
Did you also fix the problem of the wires cutting into the seat bottom foam?
If not, here's an easy fix for that, which might help the other part too.
https://www.corvetteforum.com/forums...t-fix-mod.html
To Sagging seat
