Rear End?
Old Jun 9, 2015 | 09:30 PM
Bazinga's Avatar
Bazinga
Default Rear End?
Good evening all,
I started my 12 GS A6 and let it go through my normal warm up process. Shifted into "D" and did not feel the transmission kick in, just figured I had shifted to neutral, so without looking I shifted into "S" and still no movement and no pressure on the brake pedal.
At this point I tapped the throttle and heard and felt a HUGE clunk from the rear end. I have taken the car out 2 or 3 more times since and no issue. Any clues??
I will add, that I have a 2x8 in my garage, so when I hear my rear tires touch it I know to stop (the 2x8 actually slides) but when I do touch it I always put it in gear and pull forward a bit as to not leave any stress on the transmission or rear end.
Thanks in advance for your thoughts,
Bazinga
Old Jun 10, 2015 | 09:25 PM
1SickGS's Avatar
1SickGS
Originally Posted by Bazinga
Good evening all,
Bazinga
Check your fluids. Transmission and rear end. Do that first. Then reply back and let us know. I'm curious as well, I have a 2011.
