Front Camera
Old Jun 20, 2015 | 01:49 PM
red 08 ca.'s Avatar
red 08 ca.
Default Front Camera
Hi,
Has anyone connected power for front camera to the DRL since they only come on when car is running. Currently I have them connected to my fog lights which also requires headlights as well and having to remember to turn on and off.
Any help or other suggestions would be appreciated.
Old Jun 20, 2015 | 06:41 PM
montereyredvette's Avatar
montereyredvette
I tapped into the fuse box in the passenger footwell with an on/off switch mounted in the lower dash. Or you could tap into a fuse that powers on and off with the ignition.
Old Jun 20, 2015 | 07:23 PM
red 08 ca.'s Avatar
red 08 ca.
Thanks for your response using fuse tap and switch.
Old Jun 20, 2015 | 10:21 PM
RA91925's Avatar
RA91925
When you're done, how about some photos showing your mount and also wire routing? I'm thinking that I would rather put a camera up front than to put one on the back.
Old Jun 20, 2015 | 11:56 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
DRL is just a mode of operation for your front turn signals.
When it's dark they are off, so this is probably not a good solution for powering your camera.
Using your fog lights is a pretty good idea, they will illuminate the curb/obstruction so your cam can clearly "see" it.
Old Jun 21, 2015 | 09:35 AM
sals2010gs's Avatar
sals2010gs
Originally Posted by red 08 ca.
Hi,
I have one. The guy who installed my Kenwood head unit installed front and rear cameras. Not sure how he did it but the rears work as you would expect. My front goes on when i hold down the audio button on the head unit.
To Front Camera
