Alternator problem or not
With my second replacement alternator a few days ago, I did the job myself in about 30 minutes and I'm an absolute novice under the hood....this was my first mechanical part change on my Vette (heck I've never even removed my fuel rail covers!).
In reality the job is a piece of cake. Disconnect battery. Pop off the air intake plastic assembly (one screw to loosen on the big "hose" clamp) and gently pull over the 3 rubber snap in grommets (I also removed the mass airflow sensor connector). Then it's just one wrench (15mm) on the belt tensioner to get the belt loose and off the alternator (you don't remove the bolt, just pull it against the spring load to remove the "tension" in the belt and slide it off the alternator pulley). One bolt to remove the main electric cable connected to the alternator, and one small snap in plastic cable connector right on top. Lastly a 15mm socket wrench to remove the two bolts holding the alternator to the engine.
Reverse steps above to install new one.
The only things that took any time for me were disconnecting the mass airflow sensor (I struggled to get that to disconnect without straining any of the wires....this took a few minutes for me because I was being so careful), and finding a picture of the belt path on the Internet for the front of an LS3 (I thought I might have popped the belt off one of the pulleys and I wanted to double check that I got it back on 100% properly).
Admittedly, I had a bit of confidence with my very recent "how-to" session with a master mechanic, but I really think it's a fairly easy job on a Corvette.
My 5 minute comment might have been a slight exaggeration....but only by a minute or two!
I was a little disheartened with the failure of the initial rebuilt one and have looked at OEM and some of the upgrades mentioned in this thread. The general consensus of my autocross buddies is that alternators are generally pretty reliable and that I'll probably be fine with this remanufactured unit. It has a lifetime warranty and change out is a piece of cake, so for now at least, I'm probably going to see how this one works out.
Of course I'll be kicking myself if this one breaks!
I daily drive my car and run it hard autocrossing on the weekends, so perhaps I'll have to bite the bullet and spend a little cash on quality. Of course my buddies all shared stories of OEM parts that kept failing on them too.
These upgraded aftermarket units sure do look nice (although I'm not really looking for shiny stuff under the hood), performance and hopefully great quality has me considering one of these as a next step.
I'll be looking at OEM (although wide price differences from different vendors) and perhaps the upgraded units mentioned in this thread.
Hope this is the pot of gold at the end of your electric trail.
in most cars changing the alternator is a major undertaking, one of my cars needed the engine jacked up before removing the bolts! thanks for listing the stepsWith my second replacement alternator a few days ago, I did the job myself in about 30 minutes and I'm an absolute novice under the hood....this was my first mechanical part change on my Vette (heck I've never even removed my fuel rail covers!).
Disconnect the battery positive terminal, move to the belt tensioner on the same side of the hood, take the tension off the belt and unloop the belt from the belt tension pulley and remove the wrench.
Now move to the other side of the car and on the alternator, un-clip the top wire connector harness, remove the wire from the back terminal under the rubber boot, remove the two bolts that hold it to the bracket, pull it up, turn it sideways, and it pulls right out.
Note, you don't even need to remove the fuel rail cover.
Back in is pretty much just as fast, but you loose about 1 min when you go to put the belt back on the belt tensioner and make sure that the belt is seated correctly on the pulleys and idler instead, then have to reindex the windows and set the clock time.
Note, when you reset the radio clock time, just push and hold both min and hour button in and this will kick you into time reset mode. press and hold the both buttons in again, and the radio will set to the local RDS time.
