ignition switch replacement
Old Jul 11, 2015 | 12:18 AM
Rhettvette's Avatar
Rhettvette
Default ignition switch replacement
Hello, Has anyone know how to replace the ignition in the 05. The one in the dash had all the decal or whatever they used come off. Does
someone sell an overlay to repair without removing the dash. Also the door exit buttons fell to the same problem. I guess this was one of the
many problems with the 05 year Vette. Thank you
Old Jul 11, 2015 | 12:27 AM
Batman75's Avatar
Batman75
The finish is worn from use--I'm sure it isn't unique to only 2005 C6's.
Check out this thread. I just replaced mine. Removing the dash not necessary. just release bottom bezel clips then bezel can be pulled out enough to R&R the switch. Was very easy. The aluminum bezel that holds the door release button pulls out so the release button can be changed out too. I was able to pull it out using my finger nails. The part number for the door release button is; 10362041.
https://www.corvetteforum.com/forums...n-problem.html Scroll to last reply page two.
Old Jul 11, 2015 | 12:35 AM
Batman75's Avatar
Batman75
Default Ignition switch.
Just sent PM with part number and other info.
Old Jul 11, 2015 | 12:12 PM
Rhettvette's Avatar
Rhettvette
Default Got it done this morning
Thank you to al who replied. It looks to be easy enough. As all us guys know anything plastic that snaps in
must be researched. Plastic tabs like to break off to ruin your day.
Thanks again
To ignition switch replacement
