Temperature question
Old Jul 27, 2015 | 08:50 AM
wayback's Avatar
wayback
Originally Posted by HOXXOH
After you take off the intake (air bridge) and the radiator/condenser top support, you have about an inch of space to insert a water wand and spray out the condenser from the back side.
https://www.corvetteforum.com/forums...-cleaning.html
Made a wash wand following your post a couple of years ago.
Spent 2 hours working on the condenser fins. Then removed air filter and cover and flushed them out.
Will see if it runs cooler later today after it gets hot.
Old Jul 27, 2015 | 08:55 AM
petsur's Avatar
petsur
Default Temperature question
Your oil should be 200 once warm all the time. My dry sump GS has the opposite problem being too cool, but I did manage 195 yesterday in normal driving.
Old Jul 27, 2015 | 09:11 AM
Huskerman's Avatar
Huskerman
2021 C6 of the Year Finalist - Modified
my GS runs 192 degrees on the highway with air on and bumps up to 205-212 when sitting in traffic or working it hard. Oil temps always under 200 with coolers..... If running no air conditioning it takes awhile to get the fans to come on.....with the air the fans are always on after car hits operating temps.....
Old Jul 27, 2015 | 10:30 AM
Cherokee Nation's Avatar
Cherokee Nation
Great Ideal...
Old Jul 27, 2015 | 10:47 AM
Cherokee Nation
Originally Posted by Redvette2
If you were in stop and go traffic and sitting at lights these are about right. If you were steady cruising on the highway they do seem a little bit high but not excessive. Search the forum and you should find more information.
With the stock fan setting...
Old Jul 27, 2015 | 11:49 AM
PCMusicGuy's Avatar
PCMusicGuy
On my commute home, I see a bit of stop and go and my temps are similar to yours, but with about 20 degrees higher ambient. My car is also an 07 A6 with about 112k miles on it. I see around 218 to 225 coolant temperatures, and 200 to 212 transmission temperatures. Everything is 100% stock, the coolant flush and transmission fluid change was done around 75k miles I believe. My cooling fan connector melted/failed so those are now hardwired.
Old Aug 2, 2015 | 02:34 PM
Bill Mac's Avatar
Bill Mac
Thanks for all the input. Radiator cleaning next task.
Old Aug 2, 2015 | 08:17 PM
Mad*Max's Avatar
Mad*Max
Originally Posted by Bill Mac
On a drive yesterday outside air temp was 85, oil temp 237, coolant 212, trans 212. 35 mile drive home. Do these seem excessive? Coolant was replaced this spring. 2007 base coupe A6. 63,000 miles. Thanks for any input.
spot on with my car (which is exactly the same as yours)
Old Aug 3, 2015 | 10:08 AM
Orion2011's Avatar
Orion2011
Originally Posted by okie08vette
A little high, check the front of radiator to make sure you did not pick up any obstruction.
Very possible. I ran over a plastic bag that was blowing around the interstate the other day. Looked in the rear view mirror and did not see it as I passed.
Yep sure enough it got sucked into the radiator blocking a good 1/4 of it.
Old Aug 4, 2015 | 09:30 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Only in cool temps or driving gently. Both our 2006 and now our 2009 (both A6) will show oil temps of 215-225 after a half hour of 70 mph on a 70's-80's summer day.
Old Aug 4, 2015 | 10:25 PM
Hameister's Avatar
Hameister
2015 C6 of the Year Finalist
Originally Posted by wayback
I have been working on my condenser, there are a lot of the fins bent over blocking airflow. Have a dental pic I have been using to straighten them.
Anyone know a better way?
Amazon.com: Allstar ALL10680 Radiator Fin Comb Kit: Automotive Amazon.com: Allstar ALL10680 Radiator Fin Comb Kit: Automotive
