voltage question
NSF
Sorry I can't be more specific.
https://www.corvetteforum.com/forums...ternators.html
Forum vendor is on site.
then doing some searching...my car came with a new 475 cca battery that the dealer put >
and found out the corvettes minimal cca required was 675 if im correct. me thinking that was the issue, i got myself a yellow optima battery that is 750cca. it helped but does the same thing.I know when im at a stop and the voltage drops..the a/c isnt cooler as it would be when the car is rolling. Makes sense that its a load of course.
i also noticed, but sometimes...when i first turn on the car, and as soon as i put it in reverse to get it out of my garage, it drops automatically to 13.1-13.3. then goes back to 14 when i drive.
so is this normal??
so is this normal??
The fans, seat heaters and inside ventilation fan are some of the highest current users in the car...rear window defroster also. When these are on, they will pull the system voltage down, especially at idle when the alternator is at a disadvantage. Normal.
We hit 100 yesterday and it was humid as hell. 'Bout died on the golf course. Played in Yuma one time when the temp was 107, as I recall, but it felt fairly comfortable until I grabbed an iron out of the bag. I'm thinking voltages in the low to mid 13s with the AC going and the car idling is fine, but I'm far from an expert on electrical matters. I rarely look at the volt meter.
A constant V supply will make things run better and smoother at idle. Just checked mine, ac on full at idle 14.5 V.
I had a photo of my outside thermo (in the back patio) pegged at 120' couple of years ago in July, whew, hot. Warmest I have seen was 127 in July again about 15 years ago, and that's just too dammn hot.
I think of the poor soldiers over there in that hell hole at those temps, gotta be MISERY
NSF PS August is when we get humid, SUCKS
I got this and I am pegged at 14.6 all the time...plus they come in black!
https://www.corvetteforum.com/forums...w-pricing.html
Start the car with the hood open.
Put the ground probe of the multimeter to the body of the alternator, and on the back of the alternator under the rubber boot, put the positive probe to the threaded part of the terminal (not to the cable part). You should have 14.6 volts if the alternator is good.
Now put the probes to the battery lead terminals and check voltage. The voltage should be 14.5 volts (about .1 voltage less than the alternator direct reading since you will loose this small voltage in the wiring/motor aluminum between the positive and negative paths between the two).
In the car, kick the DIC over to voltage, and the reading should be about .3 volts less than the battery reading (again, loss from the wiring/devices from the battery to the gauge cluster and if the altinator is putting out 14.6, then the DCI should be reading 14.2~14.3 .
So if you have 14.6 at the alternator terminal to the alternator body direct, but the voltage is dropping way down after that, it not a alternator problem, but a wiring connection problem instead.
The positive red cable off the back of the alternator terminal bolts to the starter on one terminal, goes through a bond bar in the starter, then to another red wire that goes back up to the battery, the a smaller red wire that goes the fuse block terminal.
On the ground side, the large negative black wire bolts to the engine block just above the starter, and another black negative wire bolts to the chassis just below the battery.
So all these wires, and there connection need to be pulled, the wire connectors cleaned, the bolting terminals cleaned, then use dielectric grease on the connecting parts before reinstalling the wires to slow them down from corroding/oxidizing again.
And as stupid as it may sound, I have seen problem of even just a bad connection from the back of the alternator terminal to the first wiring contact that has caused low voltage problems.
Note, if your DIC is reading 14.6 at idle, then the alternator is pushing at least 15.1 volts at idle to the battery instead. I bring this up, since if you are pushing more than 15.1 volts to the battery (say at mid revs and higher), then you are over voltage's the battery when it's being charged, and will shorten the life of the battery instead as you are boiling it. I bring this up for the guys that state that their DIC are holding fast at 14.6V, and may want to pull voltage on the battery when the engine is rev'd up to make sure that the battery is not getting more than 15.1 volts at any given time.
