Setting new TPMS values
Old Aug 22, 2015 | 02:20 PM
JasonCzerak's Avatar
JasonCzerak
Default Setting new TPMS values
I'm running NT05r and the car needs to run a lower tire pressure then the factory calibration.
Since the tire pressure is under 25psi, I'm getting low tires pressure. Is there a method or has someone reprogrammed the BCM to adjust that number? I'd like to make the car think that 20psi is optimal and 15psi is "low" and 25psi is "high" or something to that affect.
Please, do not preach about tire pressure and what GM says and what the tire says. I really don't care. I'm just looking to understand if I can tell the computer what I want it to run with.
Removing or disabling TPMS is an option I suppose, I'd like to avoid that if possible, it's nice having the read out.
Old Aug 22, 2015 | 02:27 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Put all the the TPMS is a canister/PVC tube/pipe/etc and pressurize it to 30 PSI.
Old track trick.
Of course you won't have sensors in your tires, but that probably doesn't matter for whatever you're doing.
Old Aug 22, 2015 | 04:34 PM
JasonCzerak
There has to be a way to re-program the computer.
Old Aug 22, 2015 | 04:51 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
You could pioneer the method and make good money off the ability to tune it. Not any publicly known method as far as I know.
Old Aug 22, 2015 | 05:01 PM
GuyFromLeMans's Avatar
GuyFromLeMans
Not sure whether or not GM offers owners the option for customized software coding as BMW does....?
Old Aug 23, 2015 | 08:28 PM
JasonCzerak
Well, that sucks.
To Setting new TPMS values
