When to replace fob battery?
Old Aug 24, 2015 | 09:36 PM
cpetruzzi's Avatar
cpetruzzi
Default When to replace fob battery?
It seems that my primary fob battery is getting a bit weak after replacing it only a year ago. I decided to use fob #2 until I got a new battery. #2 didn't work at all. I couldn't even open the door. Both batteries are about one year old. I'll get new batteries but my question is, how often should the fob batteries be replaced? Is it normal that they'd only last one year?
Old Aug 24, 2015 | 09:43 PM
Vette_DD's Avatar
Vette_DD
No, one year or less is not typical. GM says they should last about 3 years. I got 4 years on the previous ones I had.
It's possible that you got some old or bad batteries. Another possibility is that your fob has something depressed inside of it that's holding a circuit all the time.
Old Aug 24, 2015 | 10:52 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Most people seem to get long life from their fob batteries, but not me.
We drive the car a lot, ~15k miles/year.
It's set for passive locking, so every time I need to get something out of the car in the garage, it takes a fob signal (passive unlocking for me) to open the door.
I've never got a full year from a fob battery, whatever the brand. More typical is 6 months, and sometimes only 4 months.
For me, the warning is when I start to get an occasional "No Fob Detected" when trying to start or shut down, or passive unlocking starts glitching and I need to use the actual Unlock button on the fob. So I replace the battery and get on with life.
Old Aug 25, 2015 | 01:01 AM
Vette_DD's Avatar
Vette_DD
You've either got something wrong with the fob or something is pressing on your fob when you're not really using it.
With passive locking, your fob only has to be close to the door handle to allow your pull on the door handle to do the unlocking of the door.
"No fob detected" can come from strong external electronic signals near your car from exterior nearby sources.
But batteries are cheap enough, so that's a good reason not to pursue the issue if you don't want to.
Up until about a year ago, I was driving my DD C6 about 8K miles a year. Shouldn't be that much difference in how long the fob batteries last. My car stays locked when I'm not driving it.
Old Aug 25, 2015 | 01:20 AM
ProfessorDeath's Avatar
ProfessorDeath
St. Jude Donor '13-'14
When it dies.
Old Aug 25, 2015 | 04:12 AM
Grimlock13's Avatar
Grimlock13
Mine are still working flawlessly after 2 and half years so far.
The batteries in my previous 2004 GTO were still working perfectly when I sold it and those were 8~9 years old. (no passive locking/unlocking though) and those for some reason GM decided to go with soldered in batteries that were supposedly non user replaceable .
Originally Posted by ProfessorDeath
When it dies.
More like, when they start giving you problems.
Old Aug 25, 2015 | 09:24 AM
Seadawg's Avatar
Seadawg
My FOB batteries have never been replaced, and it has been a 7 days a week daily driver since February 2011.
I will replace them when I start having issues either entering or starting the car, I have a couple available, because I know I am on borrowed time.
Old Aug 25, 2015 | 10:29 AM
jimmie jam's Avatar
jimmie jam
Mine will be 9 years on January 2nd. Delco OEM battery is still in and good also.
Old Aug 25, 2015 | 11:10 AM
Gearhead Jim
St. Jude Donor '13
I agree that something is probably not quite right, but it's easier to replace the battery than try to figure out the problem. My fob has lost it's ability to retain the emergency key, so I'll try to get a complete new fob from our GMPP and see if that helps.
My "problem" happens in any location, even with the fob removed from my pocket, so it doesn't seem to be an interference issue. I also have covered the buttons on my fob with stiff plastic, to prevent accidental button pushing which is annoying and does indeed drain the battery.
"Passive" locking and unlocking aren't quite as passive as most people think, they still hit the fob with a signal. When you walk up to the locked car and press the door tab, the car then sends a signal "is there a correct fob nearby?" The fob must respond "Yes" before the car will unlock.
Old Aug 25, 2015 | 01:46 PM
2k Cobra's Avatar
2k Cobra
I replace my batteries every year. Don't need no stinkin problems when we're on a long trip.
Old Aug 25, 2015 | 02:07 PM
ZR1Cat's Avatar
ZR1Cat
I have yet to meet a battery of any kind that did not start out strong, eventually get weak and create problems, and then go **** up at a very inopportune time. Trying to figure out when the darn things are going to die is futile speculation at best.
Ergo, I replace those dinky, cheap fob batteries every two years and live problem free.
As for the car's battery, after three years of blissful service I keep an eye open for any sign of weakness and use my battery tester as required. Once I notice any sign of weakness, that sucker is history. Out with the old and in with a new one. The last thing I try to do is milk the life out of those things. It simply isn't worth it to me to be left stuck somewhere with a dead battery.
Old Aug 25, 2015 | 02:14 PM
Vette_DD's Avatar
Vette_DD
Yes, I'm aware of the "conversation" that goes on between the fob and the car.
As I indicated, as cheap as fob batteries are, it would probably be easier just to go with the way things are.
Old Aug 25, 2015 | 03:35 PM
Gearhead Jim
St. Jude Donor '13
Old Aug 25, 2015 | 06:23 PM
CSixDude's Avatar
CSixDude
The question you should be asking is how to replace the batteries in the FOB without damaging the flimsy clamshell case.
Old Aug 25, 2015 | 06:45 PM
Boomer111's Avatar
Boomer111
Agreed...
Old Aug 25, 2015 | 07:32 PM
Vette_DD's Avatar
Vette_DD
Originally Posted by Boomer111
Agreed...
https://www.corvetteforum.com/forums...ement-diy.html
When in doubt, look for a sticky.
Old Aug 25, 2015 | 08:51 PM
cpetruzzi's Avatar
cpetruzzi
Default Thanks!
thanks for all the quick replies and discussion. I guess I'll just buy some fresh batteries and not worry about it for another year. In the meantime I'll just keep driving this fabulous car. 😃
To When to replace fob battery?
Old Aug 25, 2015 | 09:22 PM
RA91925's Avatar
RA91925
You've probably done it before, but just in case, here's a DIY that may help if your fob is shaped like the one I have (2009).
https://www.corvetteforum.com/forums...placement.html
Old Aug 25, 2015 | 09:55 PM
CSixDude's Avatar
CSixDude
That is a pretty good tutorial, however, the tabs on this FOB are EXTREMELY fragile and easy to break and the FOB is not user friendly at all with regards to opening it up.
It helps if you leave it out in the sun for an hour to warm it up before you start trying to open it. Even under the best circumstances, you still have about a 50/50 chance of breaking it when you open it.
Old Aug 25, 2015 | 10:02 PM
Jim2003's Avatar
Jim2003
I had my C5 for 10 years and replaced the fobs batteries only one time in 10 years. The car had 53K on it when I got my C6. My C6 with 19K on it and 3 years old is still using the original fob batteries.
