Door swing span?
Old Sep 18, 2015 | 09:13 PM
Zero_6's Avatar
Zero_6
Default Door swing span?
I park at least 3 feet from the wall.
Old Sep 18, 2015 | 09:31 PM
unclecookie's Avatar
unclecookie
There is 4 ft. between my car and my wife's car. That's just enough room for me to be able to open my door all the way without hitting her car.
Old Sep 18, 2015 | 09:34 PM
Zero_6's Avatar
Zero_6
4ft is safe enough. I need to reverse park so I don't have to worry about the wall.
Old Sep 18, 2015 | 09:38 PM
R&L's C6's Avatar
R&L's C6
Wow, I don't even have 2 feet of room next to my workbench
It's a tight squeeze but it's doable.
Old Sep 18, 2015 | 09:50 PM
Zero_6's Avatar
Zero_6
I hate squeezing out the Vette. I want to step out with the door fully open like a boss.
Old Sep 18, 2015 | 10:30 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
My two-car garage has one wide door (I think 16 feet) and I have what has to be less than two feet between my car and hers. If I dinged her door, she'd kill me. So I have to crawl out the best I can with my door at the fist detent. It's not easy.
Old Sep 18, 2015 | 10:45 PM
Tropicana's Avatar
Tropicana
You should look into a Lambo door kit. All the cool kids have them.
Old Sep 18, 2015 | 10:57 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Same story here - less than two feet between the cars, just have to be careful. And just a reminder: it's easier to exit the Corvette in tight quarters with the side windows down.
Old Sep 18, 2015 | 11:25 PM
owc6's Avatar
owc6
It's even easier with the rear window down.
All you need to do is hop/crawl over the door.
Old Sep 18, 2015 | 11:52 PM
Zero_6's Avatar
Zero_6
With that kind of cash, I can buy headers and X pipe. My Vette will never have lambo doors but maybe gull wing doors
Old Sep 18, 2015 | 11:55 PM
Zero_6's Avatar
Zero_6
2ft and under is no good for me y'all. Gotta have at least 3ft.
Old Sep 19, 2015 | 06:58 AM
Davids65's Avatar
Davids65
My garage is real tight I have to squeeze in and out even with the window down. I can't even open as far as the first detent.
Old Sep 19, 2015 | 07:25 AM
wayback's Avatar
wayback
Same room here. I let (make) my wife park on the left side so I am the one opening the door towards her car. Much safer that way.
Old Sep 19, 2015 | 10:15 AM
09Z06pj's Avatar
09Z06pj
Veteran: Marine Corps
Please, please can we not start that up again.
Old Sep 19, 2015 | 01:46 PM
HOXXOH's Avatar
HOXXOH
This is why I required an 18' door in my new house, plus 3' clearance on one side and 5 1/2' on the other. I also went 22' deep and put a wheelchair ramp (just in case,'cause you never know) at the man door.
Currently, there is no wall between the garage and the 30 x 30 workshop, which has it's own 10' door. I'm leaning toward an accordion style partition.
I'm already old and need all the space I can get, since I can't get younger.
Old Sep 19, 2015 | 04:33 PM
dryadsdad's Avatar
dryadsdad
Squeezing? This again? If you open the door 2', you have a 1.5' gap to stroll out of like a boss or the king of Albania for that matter. Are you more than 1.5' thick? That's really thick and I have a tough time believing that you are an also an sit in a Corvette,
I'm figuring 2' gap at door end but maybe 1.5' at where you stand up closer to the door fulcrum.
You can always get Lambo doors and we can redo that wonderful thread.
Old Sep 19, 2015 | 07:43 PM
HOXXOH's Avatar
HOXXOH
I'm not sure your opinion of strolling out is near the same as mine.
I just set up a box 24" from the door and then attempted to get in and out. While I could manage, it wasn't easy, and I'm a 5'8" 175# fairly flexible guy. The door is full opened at 40", so when my mirror clears the garage door opening (and I drive in straight), I'll have 42" clearance to the wall. My Silverado and the wife's Caddy have nearly identical door openings. The old house with 3 car garage and me on the single car left side only had 16" of clearance, so I had to angle hard right just to get out of the car. The problem is that builders don't build wide enough garages. Not only did I specify an 18' wide door on the new house, I also got an 8' high one to accommodate a possible van or tall SUV.
To Door swing span?
Old Sep 19, 2015 | 08:48 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
That's 2' at the widest point ... minus the thickness of the door ... goes to zero at the hinge. There's very little space to get out. And it's even worse if you have something in your hands, like a cup of coffee. Or a pizza. You gotta be somewhat of an acrobat.
Old Sep 19, 2015 | 11:34 PM
2k Cobra's Avatar
2k Cobra
I'm slender and good looking. Can get into my GS with only 30" from the wife's car!
Old Sep 20, 2015 | 02:28 AM
Zero_6's Avatar
Zero_6
2ft gap is fine and i'll have to side step out. With the door fully open I can walk out so to speak. Maybe a sliding door mod
