Code P0601 Engine Stalling
Old Sep 27, 2015 | 09:12 PM
joejagus's Avatar
joejagus
2nd Gear
Default Code P0601 Engine Stalling
Hi Folks
Just wondering what to do with this issue . I have a 05 C6 and the car is stalling out after about 20 mins of use. It will restart after a few mins but in that 2 mins there is no voltage at all . I had the battery replaced and the Alternator checked and all good there. Is the ECM a common problem ? Would like to know if anyone out here has had similar issues. Thanks Joe
Old Sep 28, 2015 | 12:41 AM
ChevyDave's Avatar
ChevyDave
since you have at least 1 error code , you had them read somewhere or you read them yourself.
you might read up on P0601 , there are many links found doing a google for it.
also this one,,
https://www.corvetteforum.com/forums...ode-p0601.html
Old Jun 30, 2024 | 12:46 PM
RocksC6's Avatar
RocksC6
1st Gear
Default P0601
Hey Joe
My C6 with 28,000 just started doing this. The car will idle for about 15 minutes and then shut down with DIC saying redused engine speed and service active handling system.I will wait a few minutes and restart. Again i about 15 minutes , I get the same messages.
What was the outcome of your issue?
Originally Posted by joejagus
Hi Folks
Old Jun 30, 2024 | 02:45 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Originally Posted by RocksC6
Hey Joe
OP hasn’t been active since July 2016…doubt he’s still around !!…if you have a scan tool see what codes you may have…can you tell us all that is happening and maybe we can help.
Old Jun 30, 2024 | 09:21 PM
C6ToGo's Avatar
C6ToGo
Transmission Control Module?
DTC P0601-P0604 or P062F
Diagnostic Instructions
• Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
• Review Strategy Based Diagnosis for an overview of the diagnostic approach.
• Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptors
DTC P0601: Transmission Control Module (TCM) Read Only Memory (ROM)
DTC P0602: Transmission Control Module (TCM) Not Programmed
DTC P0603: Transmission Control Module (TCM) Long Term Memory Reset
DTC P0604: Transmission Control Module (TCM) Random Access Memory (RAM)
DTC P062F: Transmission Control Module (TCM) Long Term Memory Performance
Circuit/System Description
This is an internal fault detection of the control solenoid (w/body and TCM) valve assembly. This fault is handled inside the control solenoid (w/body and TCM) valve assembly and no external circuits are involved.
Conditions for Running the DTC
• The control solenoid (w/body and TCM) valve assembly runs the program to detect an internal fault when the key is ON or the engine is running.
• Ignition voltage is 8-18 volts.
Conditions for Setting the DTC
The control solenoid (w/body and TCM) valve assembly has detected an internal malfunction.
Action Taken When the DTC Sets
• DTCs P0601, P0602, P0603, P0604, and P062F are Type A DTCs.
• The TCM shifts to a default gear, shuts down, and turns OFF.
Conditions for Clearing the DTC
Diagnostic Aids
When attempting to set TCM internal DTCs let the engine run for at least 1 minute and then shut the engine off for 30 seconds. Following this procedure will allow for a complete TCM shutdown. Reprogram the TCM and retest the DTC to see if the DTC resets.
To Code P0601 Engine Stalling
